93 YJ No start - JeepForum.com
post #1 of 6 Old 08-06-2019, 03:36 PM Thread Starter
fishslayer7
93 YJ No start
Cranks, no spark no start.
Will not cough with starting fluid.
New battery & cranks well.
New ignition coil.
CPS tested bad & new one installed.
Still no spark & no start.
Plugs, wires, cap & rotor new also.
ECM???
HELP!!!!!
fishslayer7 is offline
post #2 of 6 Old 08-06-2019, 04:25 PM
mukluk
mukluk's Avatar
Check for a blown PDC fuse 1 (30a), and try swapping your ASD and horn relays.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 6 Old 08-06-2019, 08:55 PM Thread Starter
fishslayer7
All fuses look good.
Swapped relays and it made no difference.
I can hear the fuel pump.
post #4 of 6 Old 08-06-2019, 09:15 PM
mukluk
mukluk's Avatar
Will it start if you remove the ASD relay from its socket and install a wire jumper from terminal 30 to 87?
How are you checking for spark?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 6 Old 08-06-2019, 10:13 PM Thread Starter
fishslayer7
Have absolutely no clue what or where terminals 30 & 87 are.
Spark checked via screwdriver method & using a spark plug.
I fear it is time to go to the shop....
post #6 of 6 Old 08-08-2019, 10:04 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Unplug the VSS sensor in the tailshaft of the tranny and see what it does then. If it does start and run then change that sensor.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
