89 YJ w/ 4.0 not firing - JeepForum.com
post #1 of 6 Old 02-23-2020, 04:19 PM Thread Starter
DrOdie
I'm going to get to work Saturday on the YJ and just wanted to gather some ideas so I can tear into it productively. Here's the current status:
I'm getting no spark. I've put in all new plugs and wires, distributor cap, and ignition coil. Voltages to the coil check out good, so it appears everything works up until it gets through the distributor.
Is there anything I'm missing that may cause this other than a distributor issue?
DrOdie is offline
post #2 of 6 Old 02-26-2020, 11:59 AM
CodemanLivs
CodemanLivs's Avatar
1995 XJ Cherokee
I'm not sure if your model has it, but if it has a Crank Position Sensor(CPS) on the driver's side of the bell housing(up in the hardest spot to get to) against the firewall.
Then I would start with that.
CodemanLivs is offline
post #3 of 6 Old 02-27-2020, 03:06 AM
Kcooks12
Kcooks12's Avatar
Second the crank position sensor. Very common issue
Kcooks12 is offline
post #4 of 6 Old 03-05-2020, 09:30 AM Thread Starter
DrOdie
89 YJ w/ 4.2 not firing
So I misstated in my original post that this was a 4.0, when I meant 4.2. Long story short I have been in my Haynes manual and YouTube and it appears there is no CPS on this model.
The only other things I can think of is the distributor itself, the ICM, or a ground.
DrOdie is offline
post #5 of 6 Old 03-06-2020, 11:48 AM
Kcooks12
Kcooks12's Avatar
I would agree, if it were me I'd check grounds, then replace ignition coil as well as distributor cap and rotor. If still no spark then pickup coil in the distributor and icm. Should be less than $100.
Kcooks12 is offline
post #6 of 6 Old 03-08-2020, 02:34 PM Thread Starter
DrOdie
Alright, cool. I'll give it a shot and post back soon. Thanks for letting me pick your brain!
DrOdie is offline
