88 YJ runs for 10 seconds then dies - JeepForum.com
post #1 of 10 Old 07-26-2019, 01:54 PM Thread Starter
slang1
Hey I have an 88 YJ 6 cylinder mechanical carb with an HEI distributor. When I turn it on it runs for about 10 seconds and then shuts off suddenly. I put an inline fuel pressure gauge and the pressure only drops once the engine is off. The carb squirts fuel when I open the throttle right after it shuts off so I don't think that it is a fuel issue. I also hooked up my distributor straight to the battery and nothing changed. Any help would be greatly appreciated.
slang1 is offline
post #2 of 10 Old 07-27-2019, 10:25 PM
mukluk
mukluk's Avatar
Can you successfully immediately restart the Jeep every time after it dies? Does it still die after ten seconds if you hold or work the throttle to keep the engine above 2000rpm?
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #3 of 10 Old 07-28-2019, 01:03 AM Thread Starter
slang1
Yes it will restart immediatly. No matter how much gas i give it will still die between 10 and 20 seconds
slang1 is offline
post #4 of 10 Old 07-28-2019, 01:49 AM
AndyCBR6
AndyCBR6's Avatar
I’ll throw a few ideas at you... Have you considered vacuum leak? I’ve been working on brakes lately and learned that the booster could stall the engine if it’s worn out (may only happen if you’re holding down the pedal).
Have you pulled the plugs if you’re looking into the ignition side of things. Maybe you got the firing order wrong. If you pulled the distributor, could it be 180* out
Also what’s the back-story on this engine. Was it sitting for a while? Did you just put it back together? Or did this just start happening one day?
AndyCBR6 is offline
post #5 of 10 Old 07-28-2019, 02:34 AM
AndyCBR6
AndyCBR6's Avatar
What’s the condition of the ignition system components?
Fouled or broken spark plugs?
Old/damaged plug wires?
Corrosion under the distributor cap?
Cracked distributor cap?
AndyCBR6 is offline
post #6 of 10 Old 07-28-2019, 02:39 AM
AndyCBR6
AndyCBR6's Avatar
One more question... Does it run smooth or lumpy for those 10 sec?
AndyCBR6 is offline
post #7 of 10 Old 07-28-2019, 04:07 PM Thread Starter
slang1
Wow so I just tried to put an old carb on and the engine ran fine. Lesson learned never buy cheap ebay parts.
slang1 is offline
post #8 of 10 Old 07-28-2019, 07:27 PM
gutthans
gutthans's Avatar
So which 'cheap' carb did you buy off of Ebay???
gutthans is offline
post #9 of 10 Old 07-29-2019, 09:43 AM Thread Starter
slang1
I can't post a link but this is the description on eBay: CARBURETOR-FIT-JEEP-2-BARREL-BBD-6-CYL-4-2L-258CU-ENGINE-CARB-TYPE-RPW/323082738344
slang1 is offline
post #10 of 10 Old 07-29-2019, 12:44 PM
gutthans
gutthans's Avatar
All buzzwords to maximize search results. Poor grammar, ergo 'caveat emptor'.
Racing Parts Warehouse (location HONG KONG) member (China) since 10/15/2012
Draw your own conclusions.
gutthans is offline
