87 wrangler rear brakes wont work - JeepForum.com
post #1 of 6 Old 08-09-2020, 07:11 PM Thread Starter
DesertWarrior
I have an 87 wrangler with a 93 cherokee engine in it. I have replaced the MC, booster, rear lines, drums, shoes. I have bled it multiple times and have no bubbles coming out the vac at the booster is between 13-15 but the rear wheels wont stop the front wheels work just fine I even adjusted shoes all the way out and they still keep spinning like their not even there I'm at a loss for what could be the problem any suggestions would be much appreciated.
DesertWarrior is offline
post #2 of 6 Old 08-10-2020, 09:52 AM
DesertRata
DesertRata's Avatar
Were all 4 wheels braking normal at on time? What inspired you to start replacing parts? Were you trying to improve something? You've added so many parts it is hard to tell where to start in diagnosing your no rear brake problem. Perhaps if you could tell us more of the back story one of us could be of more help.
DESERT RATA
DesertRata is offline
post #3 of 6 Old 08-10-2020, 07:49 PM Thread Starter
DesertWarrior
The rear brakes never worked from the time that we bought it. the person we bought it from said he couldn't figure out why they never worked but we took a chance. We found out the drums, shoes and all the hard wear were wrong so we bough new parts for a 87 wrangler and they didnt fit so we found out the backing plates were wrong so we found a set of matching ones and got that part right and the brake lines on the rear axel were not correct (original) so we got a new set for it went through and bled everything including the mc before installing it. We also found that the passenger side e-cable was melted and was "on" all the time. We removed it. After all that, we are still at a loss.
post #4 of 6 Old 08-11-2020, 10:36 AM
V8FUN
Is the plunger in the proportioning valve stuck? I wouldn't think it is if your getting fluid, but maybe it's funky too, or perhaps even the wrong PV considering all the other stuff that was wrong.
V8FUN is offline
post #5 of 6 Old 08-11-2020, 02:28 PM
DesertRata
DesertRata's Avatar
You can not properly bleed brakes if the shoes are not contacting the drum. I would pull the rear drums off and make sure the brakes are assembled correctly. Get a hold of a service manual and compare the assembly with your assembly and make sure it is assembled correctly.
Now, put the drums and wheels back on. Next, adjust the brakes out until the wheels will not turn. Then, back up the adjuster about 3-4 clicks or until the wheel will just turn with very slight drag.
You should be able to bleed the brakes at that point.
DESERT RATA
post #6 of 6 Old 08-12-2020, 01:24 PM
rjbruzan
Most likely if they have been bled properly it is the proportioning valve. When bleeding the system is the fluid coming out in a steady stream or dribbling out? Does it have a solid pedal or spongey?
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
