4.0 Master Rebuild Kit - JeepForum.com
post #1 of 6 Old 09-25-2020, 04:33 PM Thread Starter
jkountz67
Ive got a 2003 WJ with the 4.0. Its running fine but at 237K its getting a little tired. I want to do a complete and total rebuild BEFORE disaster strikes!
Im looking for recommendations for a complete master rebuild kit. I have searched and found several but honestly they all look the same. I prefer one that allows me to select oversized bearings and such if need be, I guess I wont really know that until the machine work is done.
Just wanted to pick the collective brains here and see what others experiences have been.
Thanks!!
jkountz67 is offline
post #2 of 6 Old 09-28-2020, 08:58 AM
Mousejockey
Got mine from a guy on Ebay, name brand parts, head gasket was wrong to go figure
Make sure to check valve lash when assembled, head and block work made my push rods a tad long, had to shim the rockers
Mousejockey is offline
post #3 of 6 Old 09-29-2020, 04:40 PM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
How did you come to figure that out?
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #4 of 6 Old 09-30-2020, 08:05 AM
Mousejockey
Loud clanking when I fired it up
Its why I mention it to anyone rebuilding so they dont get the same surprise
post #5 of 6 Old 09-30-2020, 11:15 AM
BlueFl.Wrangler
Supporting Member
So how did you figure out how much shim to install?
Are there specific shims for these-- 4.0 specific?
Thanks
Winston Churchill
post #6 of 6 Old 09-30-2020, 11:58 PM
Mousejockey
https://www.summitracing.com/parts/cca-7704-1
Would have to dig abit to find the shim kit I used
Before someone chimes in, Yes you can buy push rods in the correct length you need, Yes shimming under the rocker arm does effect the geometry on the valve train.
Proper length rods are ideal
