3.7L Misfire - JeepForum.com
post #1 of 9 Old 11-13-2019, 10:54 AM Thread Starter
stevedenali
3.7L Misfire
Hi,
I have a 2005 Jeep Grand Cherokee 3.7L. It misfires only on cylinder 2(passenger front). I have put new plugs in it, swapped the coils around, put a new coil pack on cylinder 2, done a new Bosch fuel injector, and took off the valve cover to make sure all looked good and it looked fine under there. I did a compression test as a last resort and compression was good. Throttle body is clean and all other typical causes of a misfire have been checked off. The car has just over 85,000 miles on it. It misfires more at idle than in the high rpms if you watch the live data on a scanner and the misfire is much worse in the cold(check engine light flashes sometimes only in winter). I believe the computer was replaced before I purchased it because my Autel scanner says it has 130,000 miles on it and the odometer says 85,000 and the car fax lines up with what the odometer says. I am at a loss here. Any help would be greatly appreciated! Thank you!
stevedenali is offline
post #2 of 9 Old 11-13-2019, 01:01 PM
pshivers
2008 KK Liberty
Have you done a compression check?
Sent from my Samsung S8+ using Tapatalk
pshivers is offline
post #3 of 9 Old 11-14-2019, 07:10 PM Thread Starter
stevedenali
I should have mentioned that. Yes I have good compression! Thanks!
post #4 of 9 Old 11-14-2019, 08:41 PM
pshivers
2008 KK Liberty
If you can watch the live data, what are the fuel trims at idle cold and warm and at 3000rpms cold and warm? Thinking intake gasket leak made worse by the cold temps with the metal shrinking.
pshivers is offline
post #5 of 9 Old 11-19-2019, 03:16 PM Thread Starter
stevedenali
Sorry it took so long to get back to you. For some reason my scanner appears to do most everything else except for the Fuel Trims. I think I am going to do the intake gaskets anyways considering how cheap they are. I think I have gone through every other cause. Thanks!
post #6 of 9 Old 03-31-2020, 06:37 AM Thread Starter
stevedenali
It has been a long time since I have posted on this. Verified the computer was not replaced and is original. I replaced the fuel injector with a new Bosch one and still no difference. I then changed out the intake gaskets and torqued everything to spec and it changed nothing. I looked in at the intake valve while the intake was off and it looked clean and normal. It is a really strange problem. I have a special test light kit to make sure that the injector and coil pack connectors are getting adequate even power and the light will pulse with the voltage. Both tests on the injector and coil connector appeared even and normal, so that rules out a computer and wiring issue. Now, I am really confused. Any help would be great thanks!
post #7 of 9 Old 03-31-2020, 07:38 AM
Freedome04
Junior Member
Freedome04's Avatar
pull the spark plug and check the color of the plug to some of the others.At this point all I can think of is a small coolant leak into the cylinder while sitting over night.
2004 WJ Overland Freedom 4.7 H.O 156,000
Freedome04 is offline
post #8 of 9 Old 03-31-2020, 10:22 AM Thread Starter
stevedenali
I have pulled the plug, dark brown with a little black on it from the fuel not burning off. No white. Thanks.
post #9 of 9 Old 03-31-2020, 01:05 PM
jtec
jtec's Avatar
2014 JK Wrangler
Some thiughts - free and easy esp with a scanner
you are seeing a p0302?
the engine is reaching correct ECT @220?
What is o2 reading B2S1?
When head was off - did #2 chamber look cleaner than others?
What plugs are you using? ZFR6F - 11G (NGK) solid copper core
jtec is online now
