2006 Jeep LJ Idle and Shifting issues - JeepForum.com
post #1 of 5 Old 06-23-2021, 04:22 PM Thread Starter
sgtgrattan
sgtgrattan's Avatar
2008 MK Patriot
Hello,
Just recently bought a Jeep Wrangler Unlimited 2006. I have changed the spark plugs, replace the coil pack, cleaned the throttle body, new TPS, new MAP, new IOC, put midgrade and Seafoam in the tank. I still have a rough idle, its bounces around 500rpm's, drives good just bad idle. Transmission shifts hard going from first to second, until its warmed up then its fine. Im not sure where to go from here. Is it my computer, is that messing up my idle also, or an air leak? I have watched many YouTube videos, and now im stuck.
Thank you'
Kelly
"It only works when the wheels are on the ground Sir!"
sgtgrattan is offline
post #2 of 5 Old 07-02-2021, 07:53 PM
ToucanTJ
Originally Posted by sgtgrattan View Post
Hello,
Thank you'
Kelly
Okay so not saying this will fix your issue but i had the same idle problem and it turned out to be a bad upstream O2 sensor. i had gone through like 4 IAC Valves and was completely confused on why the idle kept dropping below 500.
ToucanTJ is offline
post #3 of 5 Old 07-02-2021, 08:15 PM
jtec
jtec's Avatar
2014 JK Wrangler
ok this jeep is new to you - SO i would ask
Does the CEL come on at every start for @2 seconds then go out?
I am not recognizing "IOC" help me out...
jtec is offline
post #4 of 5 Old 07-03-2021, 04:29 AM Thread Starter
sgtgrattan
sgtgrattan's Avatar
2008 MK Patriot
Thank you, I might as well give that a shot, everything else is new lol.
post #5 of 5 Old 07-03-2021, 04:30 AM Thread Starter
sgtgrattan
sgtgrattan's Avatar
2008 MK Patriot
Yes the engine light comes on then goes out, no codes are stored, and sorry the Idle Control Valve. Thank you.
