2003 grand Cherokee running hot. - JeepForum.com
post #1 of 3 Old 08-09-2019, 05:19 AM Thread Starter
tallross
running hot after five minutes on the road. ? changed the thermostat . no help. Is it possible to have a bad water
pump even if there is no leaking from the pump. The electric fan is constantly running.
tallross is offline
post #2 of 3 Old 08-09-2019, 06:09 AM
grayWJ4x4
Itís rare but it not unheard of. You could also have a bad radiator. Could be clogged or a pin hole somewhere or have a bad radiator cap.
Buy a new cap itís just five bucks and do a pressure test.
Check the oil make sure there is no water in it too.
grayWJ4x4 is offline
post #3 of 3 Old 08-09-2019, 06:24 AM
jtec
2014 JK Wrangler
this is a 2003 WJ with a 4.0L ?
The engine cooling fan is always on, AC Defrost are OFF?
What is the indication of running hot - just temp gauge, boiling over?
Yes a water pump can fail without weeping.
jtec is offline
