2000 TJ 4.0 runs rough and rich - JeepForum.com
 1Likes
post #1 of 42 Old 05-25-2019, 09:46 PM Thread Starter
Greenducky55
Greenducky55's Avatar
I have a 2000 TJ 4.0 Manual with federal emissions (1 cat)
It currently is running super rough with black soot in the exhaust. It smells of fuel really bad and burns my eyes. Sounds like a misfire but throwing 0 codes currently.
Pulled the plugs and cylinders 2,5&6 are black with 2&5 especially smelling like fuel and are black and wet.
Here is what I have done so far.
Checked resistance of coil packs. (Passed per alldata specs)
Replaced both cam and crank sensors with OEM Mopar units. (After having a P1391) prior I had cheap autozone units.
Replaced IAC with cheap unit (mine was seized)
Brand new Remflex intake/exhaust gasket torqued to spec ran and then re-torqued.
Runs rough at idle and at any throttle position. Pulling power to Injectors responds on all cylinders as expected. On cylinders 1,5&6 when pulled it runs extremely rough compared to 2,3,4. (I ran injector cleaner through all injectors with an injectors tester they all sprayed nice streams and pulsed as expected.)
I am at my wits end and hoping you can help.
Greenducky55 is offline
post #2 of 42 Old 05-25-2019, 10:53 PM
mukluk
mukluk's Avatar
For a fuel injected engine running rich, the very top of the list of suspects would be a bad upstream o2 sensor.
If you have access to a scanner that can show live data, check your manifold pressure and coolant temp readings with the engine at warm idle, and take a look at the fuel trims.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 42 Old 05-26-2019, 06:27 AM Thread Starter
Greenducky55
Thank you for the reply. I currently don’t have a scanner. Would you still suspect o2 sensors even though only 3 cylinders run rich and the others plugs look clean?
post #4 of 42 Old 05-26-2019, 08:03 AM Thread Starter
Greenducky55
I ended up ordering a set of 6 inline spark testers to check if it’s the coil at all. The pairing of 2&5 make me suspect and issue on that end. If that checks out I’m thinking I’ll just bite the bullet and get a scanner. Between the Jeep, my truck, and my wife’s car it will pay for it self fast vs the continued throwing parts at it. Does anyone have a preference of Autel vs Launch?
post #5 of 42 Old 05-26-2019, 08:19 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I agree. Test the O2 sensors, or use your OBD code scanner to view live data.
If you buy new O2 sensors only buy NGK/NTK brand sensors. Bosch and generic auto parts store O2 sensors do not work right in Jeeps.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #6 of 42 Old 05-28-2019, 10:10 AM Thread Starter
Greenducky55
So used the park testers and all 6 cylinders had spark some weaker than the others but could be the testers themself still not 100% convinced on the O2 sensors but never the less I ordered a Launch pro mini scanner at the same price of some lower models. Should be here Thursday and hopefully I can run some real diagnostics this weekend and get an answer. I’m just tired of throwing parts at it.
post #7 of 42 Old 05-31-2019, 08:03 AM Thread Starter
Greenducky55
Well here is the O2 heater Test graphs. Only 1/1 & 1/2 apply. (2/1&2/2 are for Cali emissions which I do not have) 1/1 is upstream 1/2 is downstream. Looks like the upstream sensor is bad. I’ll get a new one and see what it does.
post #8 of 42 Old 05-31-2019, 06:19 PM Thread Starter
Greenducky55
Welp new O2 sensors behave better in the scanner the Jeep no longer runs rich, but now it backfires and is missing.
Found out using the scanner I had injector 1&2 backwards. Fixed that still runs like crap.
Tested the coil packs with the scanner all have good spark. Threw new plugs in still have a few turning black.
Tested pulling injectors again all of them effect idle though cylinder 1 does not cause as rough of an idle as the others.
Evap purge working
IAC working
Map working
TPS working
To recap brand new MOPAR crank and cam sensor.
Ecu notices no misfires even when I turn the sensitivity all the way up with the scanner.
Out of ideas.
post #9 of 42 Old 05-31-2019, 06:25 PM
mukluk
mukluk's Avatar
Try resetting your adaptive memory.
1. Disconnect the POSITIVE battery Terminal and touch it to ground for 30 seconds.
2. Reconnect the Battery Cable
3. Turn Ignition Switch to the "ON" position but DO NOT start the engine
4. Turn Headlight "ON"
5. Turn Headlights "OFF"
6. Turn Ignition Key "OFF"
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #10 of 42 Old 05-31-2019, 06:41 PM Thread Starter
Greenducky55
I had reset it with the Scanner but went ahead and proceeded with the way you suggested. Still no improvement.
post #11 of 42 Old 05-31-2019, 06:46 PM
jtec
jtec's Avatar
2014 JK Wrangler
post the updated o2 sensor B1S1 graph.
Were there any codes ?
With scanner what is ECT ?
Will jeep start right up or do you need to 'prime' fuel pump?
>> thinking here is could an inj be leaking.
jtec is offline
post #12 of 42 Old 05-31-2019, 06:52 PM
jtec
jtec's Avatar
2014 JK Wrangler
FYI: Mukluk's suggestion was different than a clear code.
perform reset as he suggested.
oops I just saw you already reset.
jtec is offline
post #13 of 42 Old 05-31-2019, 07:05 PM Thread Starter
Greenducky55
Using a Launch X431 pro mini
Heres the O2 heater test. And the. I’ve uploaded some with it running. Along with a video to hear the roughness.
No codes after replacement of sensors. (Other than those I caused by pulling injector plugs)
Will jeep start right up or do you need to 'prime' fuel pump? >> thinking here is could an inj be leaking.
Fires right up I’d say.
A37D5E27-E2DE-43FD-93A5-1CCE7ED2B49B_1559351071951.jpg   8226354A-9757-414B-BED4-4D225785112D_1559351091287.jpg
post #14 of 42 Old 05-31-2019, 07:06 PM Thread Starter
Greenducky55
More photos
AE79F8C0-1E4E-445A-B2E0-CEB06FAA4F86_1559351146642.jpg   0B001754-58A3-4A97-8FC6-275C651EA5DF_1559351185951.jpg
post #15 of 42 Old 05-31-2019, 07:13 PM Thread Starter
Greenducky55
4.0 HO Swap Comprehensive How To for dummies tbunch Jeep CJ Forum 10 10-01-2019 12:09 PM
P0172 (rich) code after injector upgrade raycer911 XJ Cherokee Technical Forum 0 09-22-2018 12:24 PM
4.0 running problems PasiHolminen WJ Grand Cherokee Forum 35 08-21-2018 08:49 AM
2000 tj 2.5l rough idle SEABEEZAC TJ Wrangler Technical Forum 3 05-17-2018 05:40 PM
