1989 YJ 2.4l runs on starter fluid - JeepForum.com
post #1 of 8 Old 12-07-2019, 09:32 PM Thread Starter
GaryAbel
I purchased a 1989 yj from a one owner and been sitting in storage. The 2.4liter will run on starter fluid only. What and where should i start checking?
First post on forum, so im a newby.
GaryAbel is offline
post #2 of 8 Old 12-08-2019, 02:36 AM
mukluk
mukluk's Avatar
Is there fuel in the tank and is it relatively fresh or old and skunky? Is the fuel pump kicking on? Is the fuel line broken, kinked, or possibly plugged up?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 8 Old 12-08-2019, 01:27 PM Thread Starter
GaryAbel
new gas in tank. After church, i will check fuel pum
GaryAbel is offline
post #4 of 8 Old 12-08-2019, 05:51 PM
LaddieHanus
The 89 4 cylinder is actually a 2.5 but has an electric pump in the tank. remove the fuel line at the throttle body and turn the key on. See if fuel comes out. Might need some one to turn the key on while you watch. There is also a return line on the throttle body
Laddie Hanus
2009 JKU Rubicon
97 TJ Sahara
89 YJ
2000 Dodge/Cummins
1973 Road Runner GTX 440hp
2013 Forest River Sunseeker Class C motorhome
2004 GC Limited (Wife Jeep) 4.7 HO rebuilt 9/2016
LaddieHanus is offline
post #5 of 8 Old 12-08-2019, 06:13 PM Thread Starter
GaryAbel
I will disconnect those lines tomorrow and see if i have fuel. Is this carburetored or fuel injected?
Last edited by GaryAbel; 12-11-2019 at 07:37 PM. Reason: No fuel at throttle body.
GaryAbel is offline
post #6 of 8 Old 12-11-2019, 07:38 PM Thread Starter
GaryAbel
No fuel on either line at throttle body.
GaryAbel is offline
post #7 of 8 Old 12-11-2019, 10:56 PM
mukluk
mukluk's Avatar
Time to see if the fuel pump is working or not. If yes, check for a blockage in the supply line from the pump to the engine or for an obstructed intake at the pump. If no, check your fuses, relays (as applicable), and the pump wiring.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #8 of 8 Old 12-12-2019, 12:05 AM
Gallent
Gallent's Avatar
fuel issues
On some of these older JEEPs, you should check the pump and see if it is running, if not try checking the wiring to the top of the tank, after checking fuses etc. Sometimes the wires break, if not replace pump..
Gallent is offline
