1980 Cj7 oil pressure problem - JeepForum.com
post #1 of 4 Old 05-13-2021, 08:11 AM Thread Starter
CjFanatic86
I've got an original AMC 258 engine and I believe the valve vents are clogged because oil sprays from the dipstick port while its running, any good ideas on how to unclog these decently easily? also if anyone knows where to find a good valve cover replacement mine has needed to be swapped out for a long time but aftermarket ones never seem to fit right
CjFanatic86 is offline
post #2 of 4 Old 05-13-2021, 08:35 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
First thing to check is the PCV system. A picture of your existing system may shed light on the subject.
Do a search and you will find tons of threads on the subject.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #3 of 4 Old 05-13-2021, 09:53 AM Thread Starter
CjFanatic86
Here's one picture, I can upload more detailed ones later
post #4 of 4 Old 05-13-2021, 08:59 PM
Fourtrail
1974 CJ6
You need to run a compresion and leakdown test. Oil out the dipstick tube on a 258 is normally caused by excessive blowby.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
jeep cj7 , oil pressure , valve cover doesnt fit , valve cover leak
