08 4.7 Gr Cherokee P0300 - JeepForum.com
post #1 of 6 Old 03-12-2019, 07:21 AM Thread Starter
Megalodon47
Megalodon47's Avatar
2008 XJ Cherokee
I have an 08 Gr Cherokee with a 4.7, with about 78k miles on it. Both sets of plugs (upper and lower) were changed with same brand and part number that was in it before.
About 100 miles later, car began to miss, check engine light flashing. Code P0300 was a pending code.
Over the course of the last week I have:
Put original plugs back in
Swapped coils
Swapped boots
Swapped wires
Swapped injectors
Compression tested all 8 and they are all almost identical
When at idle, at first start up, I can watch cylinders #1 and #3 misfire, then stop misfiring when idle evens out. If gas pedal depressed/engine revved, misfires come back. They also come back under load
I have just removed the intake manifold to check gasket and to see better into the cylinder.
Going to put new gasket in, but I'm at a loss at what to do next
Megalodon47 is offline
post #2 of 6 Old 03-12-2019, 07:54 AM
jtec
jtec's Avatar
2014 JK Wrangler
confirm 4.7L eighth character of vin.
do you have a scanner to observe live data?
how did old plugs look - wet, dry, black, tan, steam cleaned, damaged,
FYI a flashing CEL is an attention getter as cat damage is likely if not addressed.
jtec is offline
post #3 of 6 Old 03-22-2019, 07:36 AM Thread Starter
Megalodon47
2008 XJ Cherokee
Yes, 4.7
I am able to monitor live data, which is how I'm able to see #1 & #3 misfiring at high cold idle then no longer misfiring at normal idle.
Old "intake" plugs dry as well as "exhaust" plugs all look identical. I'll try to see if I can post the photos of them here
Jeep has not been driven due to this issue.
post #4 of 6 Old 03-22-2019, 08:18 AM
jtec
jtec's Avatar
2014 JK Wrangler
Ok the term I wanted to check was GEN II engine. Making sure not confused with 5.7.
Intake and exhaust AKA upper and lower.
Are you SURE double check plugs against jeep NOT referencing what plugs you took out. Ignore this if you are original owner.
I would suggest a bottle of 'seafoam' or 'techron' some detergent for those injectors.
With scanner look at ECT, Fuel trims and B1S1 o2 sensor.
Try the old school carb trick for intake vacuum leak.
GTG back soon -
jtec is offline
post #5 of 6 Old 03-22-2019, 10:06 PM Thread Starter
Megalodon47
2008 XJ Cherokee
Here's first screen of freeze frame.
If you mean spray it to find vacuum leaks, I did that before breaking out the smoke machine. I may have to post these screen shots in more than one post. I apologize for my newbness
post #6 of 6 Old 03-22-2019, 10:08 PM Thread Starter
Megalodon47
2008 XJ Cherokee
next screen
05 Grand Cherokee 4.7l 4x4 P0300 SupremeFlight WK Grand Cherokee & XK Commander Forum 3 03-23-2019 11:59 AM
2004 4.7 Grand Cherokee Rattling when heater is on Bigdream1956 Engines & Drivetrain 2 11-04-2018 11:25 AM
2004 jeep grand cherokee 4.7 Tharvey177 WJ Grand Cherokee Forum 4 08-18-2018 07:27 AM
2007 Jeep Grand Cherokee 4.7 V8 Crankshaft Position Sensor amoffitt WK Grand Cherokee & XK Commander Forum 6 03-05-2018 05:17 PM
