Watsup guys the other day I hit a pole swerving away from an idiotic driver now my Jeep is messed up here's a list of what is wrong and maybe you guys can pin point what is wrong with it.
Hit left front side under the headlight minor damage on the outside upon further looking under the bumper were it hit it messed up some of the metal not the frame guessing the guard.
The car starts just fine but now when I turn the wheel it only turns a little bit to the left and turns all the way right wheels are straight steering wheel is completely the other way. Leaking MORE power steering fluid then before it also bent my rim. Now when I go to turn the car back and forth it makes a very unwanted noise not the power steering hum it's more of metal on metal sound. When I hit the pole it also threw my car into neutral from drive and stayed running. When I shake the side that got hit also makes a clunking sound from underneath the car doesn't seem to be any noticeable damage I'm gunna try to post some pics for you guys but any help I can get is greatly appreciated
