Lllneed advice on making a 32rh engine brake like a manual - JeepForum.com
post #1 of 4 Old 05-30-2021, 07:55 PM Thread Starter
bartimusmaximus
bartimusmaximus's Avatar
I have a 01 tj with 4.0 and 89 32rh. I want to be able to use my engine and gearing when traveling down steep hills to go slow instead of using my breaks. In the same manner you can use a manual transmission. Is this possible and how/what is needed? I've searched and I've been reading for days. But I can't find the specifics of what needs to be done. What needs to be purchased and installed. Any help would be greatly appreciated. Thanks
bartimusmaximus is offline
post #2 of 4 Old 06-05-2021, 06:17 AM
V8GCZJ
I think it could be possible if you install a switch for the lock up converter. But you will have to release the switch or when slowing down(to stop) you could stall the motor.
V8GCZJ is offline
post #3 of 4 Old 07-01-2021, 12:13 PM Thread Starter
bartimusmaximus
ok. Thanks. Is it possible to install this switch with a 32rh from.a 87 yj that has no electronics? Or do I need to find a newer version to do this?
post #4 of 4 Old 07-03-2021, 07:39 AM
V8GCZJ
V8GCZJ is offline
