JeepForum.com (https://www.jeepforum.com/forum/)
-   Street Jeep Forum (https://www.jeepforum.com/forum/f180/)
-   -   Lllneed advice on making a 32rh engine brake like a manual (https://www.jeepforum.com/forum/f180/lllneed-advice-making-32rh-engine-brake-like-manual-4434167/)
bartimusmaximus 05-30-2021 07:55 PM
I have a 01 tj with 4.0 and 89 32rh. I want to be able to use my engine and gearing when traveling down steep hills to go slow instead of using my breaks. In the same manner you can use a manual transmission. Is this possible and how/what is needed? I've searched and I've been reading for days. But I can't find the specifics of what needs to be done. What needs to be purchased and installed. Any help would be greatly appreciated. Thanks
V8GCZJ 06-05-2021 06:17 AM
I think it could be possible if you install a switch for the lock up converter. But you will have to release the switch or when slowing down(to stop) you could stall the motor.
bartimusmaximus 07-01-2021 12:13 PM
ok. Thanks. Is it possible to install this switch with a 32rh from.a 87 yj that has no electronics? Or do I need to find a newer version to do this?
V8GCZJ 07-03-2021 07:39 AM
https://transmissioncenter.net/shop/...p-information/
The time now is 02:56 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
