I need help deciding on an amp. - JeepForum.com
post #1 of 13 Old 04-08-2007, 11:26 AM Thread Starter
Jeepokee
I know nothing about amps so I'm pretty clueless. I have 6.5" Infinity 6012si all the way around and they need more power than my Pioneer deck can provide. In the future I will most likely run just an 8" sub in the rear panel because I need the cargo space so I'd like to plan ahead.
http://www.crutchfield.com/S-FOFe8Fx...00&I=1086012SI
The speakers have 2-50 watts RMS (150 watts peak power).
I'd like to keep my budget kinda low ($150ish or less) so going used is not out of the option. I just want something to provide adequate power to the speakers and work well with one future sub. I don't listen to rap/hip-hop so it doesn't have to set off car alarms, but I listen to rock so I need something that can provide a punch.
And if anyone can suggest a sub to go with the amp that'd be great too.
Rock Lizard Fabrications 2.5" Leaf Pack Kit, Monroe Sensa-Trac Shocks, 30x9.5 Firestone Destination M/T, 15x7 Cragar Soft 8s with 4" BS, APN Header, Magnaflow Cat, Flowmaster 50 Delta Flow
Jeepokee is offline
post #2 of 13 Old 04-08-2007, 11:51 AM Thread Starter
Jeepokee
Should I be looking for a 4-channel amp just to power the speakers and get a separate amp to power the sub? My deck has 2 sets of RCA inputs.
Jeepokee is offline
post #3 of 13 Old 04-08-2007, 11:54 AM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
I dont know that much about it, but i think you need a channel for every speaker you are hooking up
oh and i think it is best to have a separate amp for the sub at least that how i see everyone does it
Arcticcat843 is offline
post #4 of 13 Old 04-08-2007, 12:18 PM
kingofthehill
Guest
you mean 2 sets of outputs right ? assuming I'm right it probly only has front and rear channels and left and right for each the front and rear channel. so in short yes you are looking for a 4 channel amp and when you finaly do decide to get a sub just use 2 y connectors like these
to split the rear channel and then go buy a cheap mono block (single channel) amp and a cheap 8' sub and you will be set
kingofthehill is offline
post #5 of 13 Old 04-08-2007, 12:26 PM Thread Starter
Jeepokee
Yeah they are outputs. Sorry bout that. So in short, right now I should get a 4-channel amp to power my 4 speakers and then when I do get a sub I should get a mono-channel amp?
Jeepokee is offline
post #6 of 13 Old 04-08-2007, 12:37 PM
alexrule123
alexrule123's Avatar
here you go 40watts rms x4 for $159.99
http://www.woofersetc.com/index.cfm?...roduct_ID=3729
edit: just found this one for $139.99
http://www.woofersetc.com/index.cfm?...&Product_ID=65
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #7 of 13 Old 04-08-2007, 12:52 PM
kingofthehill
Guest
yeah just like those
alpine ftw
post #8 of 13 Old 04-11-2007, 05:41 PM
sprngrider
If you are only running 4 speakers you can also get a 2-channel amp. You dont have to only look at 4-channels.
sprngrider is offline
post #9 of 13 Old 04-11-2007, 06:37 PM
mizzouxj
Rockford Fosgate FTW!
2000 White XJ Sport | 2" Rough Country | 15x8 Eagle Alloys Series 187, 30x9.50 Dayton Timberline A/Ts | Carr Light Barr w/ 4 KC 100W 69 series | Custom Tube Bumpers from my old XJ | Complete Rockford Fosgate Sound System with Alpine Headunit
mizzouxj is offline
post #10 of 13 Old 04-11-2007, 07:07 PM
alexrule123
true, i am running a 2 channel, but you lose the ability to fade from front to rear
post #11 of 13 Old 04-12-2007, 06:31 AM
misguided96
Guest
Not meaning to hijack the thread but....I have the same situation, I would like a small sub to go in the rear panel to save space but I'm not sure where to place the amp. I thought I heard people placed it under the back seat. Would this work? I thought it might over heat. Any help would be great.
misguided96 is offline
post #12 of 13 Old 04-12-2007, 12:05 PM
alexrule123
i placed mine under my backseat, i just added an 80mm computer fan to keep it cool
post #13 of 13 Old 04-12-2007, 12:57 PM
misguided96
Guest
thanks for the help
Deciding on B&M Shifter gmshades Engines & Drivetrain 1 04-17-2009 07:38 AM
Need help on deciding which Stroker 2004WRANGLER Engines & Drivetrain 8 09-22-2008 06:49 AM
deciding between 304 and 360 muddmonky Engines & Drivetrain 12 08-16-2007 05:16 PM
Need help on deciding which lift to get richnev Tires & Wheels 7 07-26-2007 05:42 PM
deciding on tires goldnjeep Tires & Wheels 3 04-16-2007 08:05 AM
