Building a hotrod XJ - Page 2 - JeepForum.com
post #16 of 20 Old 08-29-2016, 10:24 AM
RedJeepster1
RedJeepster1's Avatar
Are you familiar to the XJ-R build? If not, google it. It was a pretty cool Cherokee that was lowered and set up to run a road course. And it was done on a budget. They but and notched the front axle to have more camber and to clear the oil pan. Ran shorter stiffer front springs in the front. They built bastard packs in the rear and went to a spring under axle setup. Since the XJ's are over, the only way to really get the rear end any lower without having inverted leaf springs is to swap to a spring under axle setup. This is the build thread. They also have a website somewhere that talks about it but this is what I could find on my phone during lunch.
NAXJA Turbo XJ-R Build Thread
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 Silver XJ, 4.0, AW4 with 350k+, Locked C8.25 w/ Chromos, Trussed hp30, 4.56's, Stiffened, IRO leafs, RE coils, custom 3 link, WJ knuckles, 35's
RedJeepster1 is offline
post #17 of 20 Old 08-29-2016, 04:46 PM
Wheelman04
Originally Posted by xrunndonex View Post
I can make decals
My Aunt also runs a vinyl decal business but if need anything I'll shoot you a pm
Wheelman04 is offline
post #18 of 20 Old 09-26-2016, 06:42 PM
CobraMarty
Look at my white 'racejeep' on CF. Lowered to the bump stops and then cut them 1" for travel. There is a bunch more to it.
'98 XJ AW4 4.0 SUPERCHARGED M90 225+HP
Jeep M62/90 XJ TJ JK Supercharger Expert, PM any Questions
CobraMarty is offline
post #19 of 20 Old 09-28-2016, 05:30 AM
AFRd_CJ5
1976 CJ5
Wrong thread
'76 CJ5
430ci E85 SBC/single plate system
th400/Coan converter/DTS 9" rear
Family grocery getter
AFRd_CJ5 is offline
post #20 of 20 Old 09-28-2016, 02:30 PM
CobraMarty
HERE-
http://jeepm62superchargerkit.blogsp...-racejeep.html
or HERE-
http://www.cherokeeforum.com/f46/pro...cejeep-173699/
