XJ a hot item ? Value of renix XJ's today - JeepForum.com
 1Likes
  • 1 Post By CJ7-Tim
post #1 of 7 Old 07-05-2020, 03:41 PM Thread Starter
dan66cj5
1966 CJ5
I just sold a 90 XJ that was sitting under a tree for years for $450, more than my asking price. I sold it in less than 24 hours and the guy gave me the money before looking at it. It didn't run, engine was leaking coolant out of the frost plug- that's why it was parked.
Did I give it away or what ? Heres a pic..
I got a 89 I want to sell as well.. but I want 2,000 for it, because I think I could part it out for that much on the good stuff I have on it. Whats it worth and what are the parts going for today ? It runs and drives.. d44 rear with disc brakes, d30 front with locker, 4.0 with upgraded injectors and headers, auto trans, 231 t/c, copper 3 row radiator, not sure what else..
66 CJ5 Dauntless V6, 89 XJ Renix 4.0, 96 ZJ 5.2 V8, 04 WJ QD 4.7 V8
dan66cj5 is offline
post #2 of 7 Old 07-09-2020, 09:54 AM
riderboy1961
riderboy1961's Avatar
"on Paper" your 89 sounds Highly Desirable. Apparently those d44 rear ends are hard to find and very well built. AND... your front end is probably the higher desirable "High Pinion D30" plus you have a Locker in It.
Thank You,
Bo
riderboy1961 is offline
post #3 of 7 Old 07-09-2020, 09:59 AM Thread Starter
dan66cj5
1966 CJ5
Yes, I’m trying to figure out how much they are going for(the d44). The front hp30 is a good one, but they are common. They came in every xj up to 2000 I believe
dan66cj5 is offline
post #4 of 7 Old 07-09-2020, 03:59 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I used to sell XJ D44's for $5 - 700, plus shipping. I can't find them anymore. High pinion D30 ran thru 1999, 2000-01 XJ are low pinion. IMO non vaccum disconnect D30 are better/worth more.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #5 of 7 Old 07-09-2020, 07:01 PM
riderboy1961
Is the non vacuum disconnect the High Pinion or Low Pinion D30?
Thank You,
Bo
post #6 of 7 Old 07-10-2020, 04:55 AM
CJ7-Tim
CJ7-Tim's Avatar
All XJ Cherokee D30 were high pinion until 2000. XJ Cherokee 1990 and before were built the with vacuum disconnect, NP242 transfer case always had a non-disconnect axle. Jeep used leftover disconnect axles in early 1991 production but those were transition vehicles, most 1991 XJs did not have vacuum disconnect.
riderboy1961 likes this.
CJ7-Tim is offline
post #7 of 7 Old 07-10-2020, 10:48 AM Thread Starter
dan66cj5
1966 CJ5
Yep. I have the vacuum disconnect and high pinion. I converted it to non disco axles with the bigger u joint axles.
dan66cj5 is offline
