What all can I harvest from a WJ? - JeepForum.com
post #1 of 9 Old 07-16-2019, 01:07 PM Thread Starter
CleanJay
CleanJay's Avatar
I'm going to buy a 2000 Grand Cherokee for the seats and then part it out. My question is, what else can i utilize in my 2001 XJ? I was thinking maybe the alternator, speakers, steering wheel, stuff like that. Maybe some suspension components, the underside of mine is all rusted out.
Side question: Do they make front grille covers without the turn signal holes in them? I think they stick out like a sore thumb, and I didn't wanna have to resort to tinting them. I don't like the white ones.
CleanJay is offline
post #2 of 9 Old 07-17-2019, 09:06 PM
chris87xj
RIP Chris87xj
chris87xj's Avatar
1987 XJ Cherokee
I don't think you'll find a lot as they're totally different vehicles in body, frame, and drive train.
***Chris***
chris87xj is offline
post #3 of 9 Old 07-20-2019, 05:07 AM
Ralph77
Is it a 4.0?
Check the head.
Chances are it is a 0331 head.
Which is the same as your Jeep.
Which appear to have a habit of cracking.
But if it was replaced at some point with a TUPY head then grab it.
Ralph77 is offline
post #4 of 9 Old 07-21-2019, 08:34 AM Thread Starter
CleanJay
CleanJay's Avatar
Originally Posted by Ralph77 View Post
Is it a 4.0?
Check the head.
Nah it's the v8.
CleanJay is offline
post #5 of 9 Old 07-28-2019, 10:14 PM
tyvanwie
tyvanwie's Avatar
1993 XJ Cherokee
You can swap the knuckles and run WJ steering. Bit of work, but you can do it for a nice upgrade. Control arms may work.
tyvanwie is offline
post #6 of 9 Old 07-29-2019, 09:26 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Can you use XJ hubs in the WJ knuckles?
D3<!L!>3D
S8NNG8 is offline
post #7 of 9 Old 09-18-2019, 04:32 PM
lrsmithwhaley
1990 XJ Cherokee
You can swap the brake booster. https://www.cherokeeforum.com/f67/bu...pgrades-84020/
Green with Silver trim 1991 Jeep Cherokee Laredo (DD and Off-roader)
March 2007 Stock Class XJ of the Month
Original Rust Jeep Club Member #2
Green Jeep Club Member #183
Air Force Jeep Club #76
lrsmithwhaley is offline
post #8 of 9 Old 09-19-2019, 09:00 AM
75SV1
Yes, the fit. You need the '00-01 hub bearings. I think I read somewhere recently, the '06 TJ hubs are the same, but with a bit longer thread studs. Also, a 1/4 spacer needs to be welded on, to keep the pivot point of the axle shaft at the same point. The WJ Hubs will work is you want to go 5 on 5. I did this recently. Still need the 1/4 space that needs welded on. Also, 07-08 Libby/Nitro front rotors are a direct bolt on for 5 on 4.5 setup. Also, need to space out the front calipers 1/4. I didn't when I had the 5 on 4.5 setup. I had to on the 5 on 5. I an running R17 WJ rims I think or JKs.
If V-8, they might have a trans cooler. They are about 7" X 9". They are attached to a 'mini bull bar'. I am going to try and fit that to an XJ. I need to lengthen them a bit to attach to the front frame on an XJ.
75SV1 is offline
post #9 of 9 Old 09-19-2019, 09:12 AM
jtec
jtec's Avatar
2014 JK Wrangler
the WJ part car is a V8?
you want the FAN and hydraulic valving*, If there is also a elec fan, also grab the PCM, write down all info, Alternator, then look for SRS elec components,
What does not interchange A WJ owner will need, all the mentioned parts and some - a local jeep club might make you more friends as the salvaged WJ would be a nice to have.
As these jeeps get on in years its the classic car mentality someone will need this...
jtec is offline
