Subs install help - JeepForum.com
post #1 of 7 Old 11-18-2013, 05:39 PM Thread Starter
Turcsi_Wheeler
Subs install help
Not sure if anyone here is very good with installing radios and what not but I can't figure out why my amp won't turn on. The power wire and ground are good because when they touch they spark like crazy. That means it must be the remote wire right? I hooked it to the blue wire with line and nothing happened. I then unhooked the two blue wires and turned the car on again, and the radio still turned on. So I figured the blue/white wire wasn't the remote wire because the radio turned on. I then tried splicing the rem wire with all the other wires and the amp still won't turn on.
Any ideas?
Turcsi_Wheeler is offline
post #2 of 7 Old 11-18-2013, 05:43 PM Thread Starter
Turcsi_Wheeler
And yes I did check every fuse and they're all good.
post #3 of 7 Old 11-18-2013, 08:37 PM
freestylekid33
freestylekid33's Avatar
See if it works if you just run a jumper wire from power to REM on amp, that will tell if amps good. And usually the remote turn on from the deck is solid blue.
freestylekid33 is offline
post #4 of 7 Old 11-19-2013, 10:03 AM
96xjKing
I spliced mine with the red( power) wire from the CD player harness so whenever the CD player was on my amp was on, however I would try freestylekid's idea if I was you, just to see if it the amp works or not, if it works then you know it's wiring, if it don't then theres your answer
96xjKing is offline
post #5 of 7 Old 11-19-2013, 01:06 PM
usawrestler95
the REM tells the amp when it should turn on and off. It has nothing to do with your radio turning on.
usawrestler95 is offline
post #6 of 7 Old 11-19-2013, 04:43 PM
freestylekid33
The blue wire just tells amp when radio is on usawrestler.... so if you splice into the red wire which gives radio power to turn on it essentially does the same thing...
post #7 of 7 Old 11-20-2013, 12:45 AM
usawrestler95
You misinterpreted what I said. I meant it as the REM doesn't actually turn your radio on. Like it doesn't control the power. I understand exactly what the REM does. "So I figured the blue/white wire wasn't the remote wire because the radio turned on." That's what I was responding to.
