Should I buy a XJ?!? - Page 4 - JeepForum.com
post #46 of 56 Old 01-02-2013, 03:54 PM
BlueBadger
BlueBadger's Avatar
Originally Posted by BlaineWasHere
What about highway MPG? With everything running well can I get 17MPG going 70MPH with 33x10.5s? What gearing do the 97-99s usually come with?
I have a '92 with a 3" lift, 3.55-1, trimming and 33-12.5's. I get just above 18 mpg hwy while running about 65. but I also have the ax-15 5 speed. D30hp and D35. Never had any axle issues with moderate wheeling, picking good line and trying to make my right foot play nice with the skinny peddle.
I know you said you don't want to do an axle swap. But if some day you decide to. A ford 8.8 out of an explorer goes in with little work. Stronger then all the XJ axles. And you can get them with disc brakes, gear ratios choices out the butt and limited slip and posi tracks are very easy to find. Most of the v8 options had those. Good luck.
BlueBadger is offline
post #47 of 56 Old 01-05-2013, 02:08 AM Thread Starter
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I'm willing to wait it out, but, I've seen V8 WJs for the same money as XJs. Is there any other good places to look other than Craigslist?
2013 FR-S
BlaineWasHere is offline
post #48 of 56 Old 01-05-2013, 08:47 AM
rebelbowtie
rebelbowtie's Avatar
I use autotempest.com for finding used cars.
rebelbowtie is offline
post #49 of 56 Old 01-05-2013, 10:16 AM
Tylerzap
Humm thats weird. I got my XJ already lifted with a busted T/C (NP242) for $750 and repaired it for $100 and changed all the fluids including diff and have a little over $1000 put into it.
You should be able to get a good deal on one if you open yourself up to one that needs minor repairs and spend your extra money on mods and stuff..
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #50 of 56 Old 01-05-2013, 01:46 PM Thread Starter
BlaineWasHere
BecauseRacecar
I would buy one that needs some minor stuff, but nothing major like blown tranny or bottom end motor work, or a ton of small problems that will all add up.
2013 FR-S
post #51 of 56 Old 01-05-2013, 02:20 PM
Tylerzap
Makes sense. Mine had a messed up T/C, and the exhaust was unhooked but that was it and the TC was easy to replace.
Tylerzap is offline
post #52 of 56 Old 01-05-2013, 02:45 PM
Motorcharge
Motorcharge's Avatar
WJs don't hold resale value. We don't even put them on the lot anymore at work, we send em to wholesale and I've seen us put 99-01 XJs with low miles on them on the lot for $10k+ and have them sit there less than a day.
Since cash for clunkers XJ prices have gone way up, esp mint condition ones or low mileage. Demand for them is still useage but supply is way down.
As for where to look, Cherokee Forums classifieds always have stuff on them. I got my current XJ on there for $400 a couple months ago.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #53 of 56 Old 01-05-2013, 09:00 PM
dmill89
1995 XJ Cherokee
Most people don't really want a V8 WJ. There is a reason why they don't hold their value very well.
They have the 4.7L OHC V8 which is failure-prone and costs much more than the 4.0L I6 or older 5.2L/5.9L V8 to maintain and repair. Add to this the weak transmissions on the WJ; 42RLE on the I6 and 45RFE/5-45RFE on the V8 (the 45RFE/545RFE aren't terrible behind a 6-cyl such as the early Liberties but don't belong behind a V8). If you want a V8, a ZJ with the 5.2L/5.9L V8 and 46RH/46RE (truck transmission) is a far better bet. Of course it is hard to beat the simplicity of an XJ. Any GrandGherokee is likely going to have more problems and be more difficult to work on since they are a more modern and complex design.
dmill89 is offline
post #54 of 56 Old 01-05-2013, 09:07 PM
Tylerzap
I dont agree with the 4.7 thing. I have a dodge dakota with that and ive never had a problem with it. Lots of power, good gas mileage, and reliable.
Tylerzap is offline
post #55 of 56 Old 01-05-2013, 09:27 PM
dmill89
1995 XJ Cherokee
It's largely a matter of luck with the 4.7. The 4.7 is known for all kinds of problems. It has thin cylinder walls that are known for cracking, oil sludge issues, overheating and cracked head issues, timing system issues, PCV /oil foam issues, etc.
Many of these issues come on as a result of lack of / improper maintenance, which of course is a major risk with a used vehicle. Like the 0331 head issues on the 00-01 4.0, not all 4.7s will have these issues and proper maintenance significantly reduces the risk but I would be very hesitant to buy any used vehicle with the 4.7 unless it had a full maintenance history.
dmill89 is offline
post #56 of 56 Old 01-06-2013, 10:18 AM Thread Starter
BlaineWasHere
BecauseRacecar
I owned a 4.7 and it was great. I bought it with 60K miles and never had a single issue until I sold it around 120K miles, but IMO that's not really that high of millage either.
2013 FR-S
