Rear Leaf Springs on 1997 XJ - JeepForum.com
post #1 of 7 Old 05-15-2019, 05:15 PM Thread Starter
WmBlack318
1997 XJ Cherokee
Hi gang, newbe here. But, plan on hanging around awhile. I've had this jeep for awhile, and plan on keeping it longer. I'm here because of an issue I need help with. rear leaf broke in two places, and I've heard it's a common problem. Is it? Also heard the leaf springs off a Chevy S10 will fit, and give a 4" lift. Any truth, or ideas here?
WmBlack318 is offline
post #2 of 7 Old 05-15-2019, 06:03 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Do you want to lift it or just fix it ? What is the budget, and what are the goals for the suspension ? Have you researched the additional modifications/expenses required for lifting the suspension 4 inches ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 7 Old 05-15-2019, 06:16 PM
downs
downs's Avatar
1995 XJ Cherokee
S10 (or Dodge Dakota) leaves aren't a direct swap in. You build what's called a bastard pack with them. Basically disassembling your stock leaf pack and using a combination of leaves from your leaf pack and the donor pack to build a leaf pack to the height you want.
4 inches of lift is going to require a lot of extra ($$$) stuff to do it properly.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
post #4 of 7 Old 05-15-2019, 06:21 PM Thread Starter
WmBlack318
1997 XJ Cherokee
Thanks, i'm not going to lift it. Just looking for replacement springs. Just found some thanks.
post #5 of 7 Old 05-15-2019, 08:19 PM
downs
downs's Avatar
1995 XJ Cherokee
If you don't want to lift it just go with some Crown or General Spring replacement springs.
downs is offline
post #6 of 7 Old 05-17-2019, 08:05 AM
MaskedMallard
Xj
This is a little bit of a late reply, but here is where I found my replacement leaf springs.
https://www.quadratec.com/vehicle/19...n/leaf-springs
2001 BJC Orvis XJ Build -
MaskedMallard is offline
post #7 of 7 Old 05-17-2019, 11:49 AM
downs
downs's Avatar
1995 XJ Cherokee
Theyre a little cheaper on amazon. Not by much but a little and much faster shipping than Qtech.
Sent from my SM-G892A using Tapatalk
downs is offline
The Modified Superlift Thread USN_BlackWK WK Grand Cherokee & XK Commander Forum 95 05-06-2020 02:59 PM
2018 YJOTY - Vote Now!! bruinjeeper YJ Wrangler Technical Forum 42 01-11-2019 07:01 PM
December 2018 YJOTM - Vote Now! bruinjeeper YJ Wrangler Technical Forum 44 12-29-2018 06:22 AM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
Call me stupid, tell me I didn't search the threads-too bad I did. AAl vs RLS HornedFrogHooah XJ Cherokee Technical Forum 23 04-24-2010 12:33 PM
