Ceramic coating & underhood temperature - JeepForum.com
post #1 of 10 Old 10-09-2016, 10:54 AM Thread Starter
PimaXJ
1997 XJ Cherokee
From what I have read, the ceramic coated headers are very expensive but imo the only way to go. Comparison of surface temperature reduction between coated & uncoated headers by fifty degrees is no small matter. Will likely have the extension pipe coated too after I add a flex joint to it. Another consideration is to have the intake manifold coated. JEEP- just empty every pocket!
PimaXJ is offline
post #2 of 10 Old 10-09-2016, 02:36 PM
shooptube
Big Brother
shooptube's Avatar
1997 XJ Cherokee
You could always buy a nice new header and ceramic coat it yourself. Opens up many more options.
Originally Posted by Luke95 View Post
I am Moar low.
Build Thread:
Instagram:
shooptube is offline
post #3 of 10 Old 10-10-2016, 08:39 AM Thread Starter
PimaXJ
1997 XJ Cherokee
@shooptube I considered that but the inside of the header needs to be coated too. The most challenging aspect is to install it without scratching it!
PimaXJ is offline
post #4 of 10 Old 10-10-2016, 12:24 PM
bluejunior
bluejunior's Avatar
Wrap it in painters tape or even athletic tape, then peel it all off after it's installed. Makes the no-scratch thing WAY easier, though the unwrapping will cost you a scraped knuckle or two in all likelihood.
Lifted, Locked, Stiffened
bluejunior is offline
post #5 of 10 Old 10-10-2016, 08:25 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Or just stick it in a pillow case and tape it up near the top flange. Once it's bolted to the block, you can pull the pillow case off from below.
D3<!L!>3D
S8NNG8 is offline
post #6 of 10 Old 10-11-2016, 09:10 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
I can't speak for shooptube, but when I read his comment I thought he meant that you could buy any header that you like, and then send it to a place like Jet Hot to have it coated (you would likely be able to find a local place that could do it as well). Not that you should buy the spray can stuff and actually coat it yourself....
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #7 of 10 Old 10-16-2016, 08:16 PM
RacerX
1989 XJ Cherokee
I got some of that spray-on ceramic stuff at NAPA.
I did the front rotors - it says to bake at ... 200 or 250 degrees F for maybe 30 min. , then after cooling, 450 or 500 F for 30 min.
After that install and get it hot ... well I don't have a real big (long enough) hill nearby , so probably not completely cured yet ?
Should be simpler for headers, down-pipe, muffler? - (I'd like to do those too soon)
4-wheeling is about going where others can't won't or don't think it's safe.
Freedom. Exploring the wilderness, or nature, whatever... - NOT paying to go on someone's roller-coaster ride, or go-cart track!
"The price of freedom is eternal vigilance." - Thomas Jefferson
RacerX is offline
post #8 of 10 Old 10-17-2016, 08:19 PM Thread Starter
PimaXJ
1997 XJ Cherokee
I have not looked into the cost of having a header coated but it is likely the header manufacturer that provides the ceramic coating will offer a better warranty but not certain. I like the pillow case solution! Likely to go with brown construction paper & a lot of tape. Much to do before I get to this but I do like to plan my expenses ahead! Thanks to all for the comments & suggestions!
PimaXJ is offline
post #9 of 10 Old 10-17-2016, 09:19 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
I haven't looked lately, but Jet Hot used to offer a real lifetime warranty on anything they sold or coated. I had a friend warranty a set of small block chevy headers that had been left in weeds behind a shop for 8+ years, no issues from Jet Hot. He paid to send them back to them and they cleaned them up, re-coated them, and mailed them back in just over a week.
Their service isn't cheap, but if their quality and service is still at or near that level, they are definitely worth looking in to.
- Justin
post #10 of 10 Old 10-24-2016, 12:25 PM
75SV1
I did have a set of headers done by Jet Coat in the mid 90's. It was $300. Quality work. I haven't run that car much. I also coated the trans tunnel. Made a huge difference. '75 Bricklin. Make an XJ seem like a refrigerator. Also, had a set of the Armour coat Pace Setters. Held up for at least a year. Some chips around the edges. I did have a local shop do a -00+ intake. I can't remember the price. A lot of the price is sandblasting. So, if you have acces to one, it might same some $$.
75SV1 is offline
