an annoyance when starting my xj - JeepForum.com
 1Likes
  • 1 Post By S8NNG8
post #1 of 4 Old 06-19-2019, 10:03 AM Thread Starter
Submariner
Submariner's Avatar
when starting my 99 2 dr, 4.0. 4wd automatic.
turn the key, engine rolls over and it won't start.
Turn if off and turn the key for the second time and it starts right up. Runs smooth, no issues
But sometimes it won't really start, but acts like it is only hitting on one or two cylinders, turn it off and then turn the key ans she starts right up.
Runs smooth, getting 18 mpg, everything works, No codes.
So what do you make of this? I feel that one day I am going to have a problem, just trying to stay ahead of the game.
Submariner
Submariner is offline
post #2 of 4 Old 06-19-2019, 11:13 AM
jtec
jtec's Avatar
2014 JK Wrangler
check fuel pressure with a gauge -
turn key to ON observe and post highest fuel pressure, leave key ON post fuel psi after 5 minutes.
Check codes post all codes you have.
When it will not start - can you with a helper check for spark, pulsing injectors.
jtec is offline
post #3 of 4 Old 06-20-2019, 05:40 AM
shooptube
Big Brother
shooptube's Avatar
1997 XJ Cherokee
Next time its been sitting overnight, turn the key to on but dont start, wait 3 seconds, key off and back on wait a sec then try to start.
I bet it will start perfectly.
I think that its the one way valve in the fuel regulator letting fuel drain back into the tank.
Originally Posted by Luke95 View Post
I am Moar low.
Build Thread:
Instagram:
shooptube is offline
post #4 of 4 Old 06-21-2019, 07:59 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I use the seat belt buzzer as a timer. Key on...buzzer stops...start the engine.
Submariner likes this.
D3<!L!>3D
S8NNG8 is offline
