AIC's BFG - Build thread - Page 10 - JeepForum.com
post #136 of 516 Old 09-17-2014, 07:07 PM Thread Starter
aroundincircles
1989 XJ Cherokee
Picked up an electric impact wrench, we'll see how it does tonight, but tonight is the night I volunteer at an employment center so I won't be home until later tonight...
89 Cherokee
aroundincircles is offline
post #137 of 516 Old 09-18-2014, 05:15 AM
LKWJEEPER
2009 KK Liberty
PB Blaster is going to be a necessity. I used the the handle to a jack to use as a breaker bar on mine. The front spring bolt was stuck. So it was a pain in the arse.
Best to start soaking in PB now before you start.
LKWJEEPER is offline
post #138 of 516 Old 09-18-2014, 06:18 AM Thread Starter
aroundincircles
1989 XJ Cherokee
I've been hitting it with pb blaster since aug. I have broken a socket and a breaker bar. Next up is the impact wrench. See what that does.
89 Cherokee
post #139 of 516 Old 09-18-2014, 06:49 AM
JeepN4KC
JeepN4KC's Avatar
You are probably gonna need to hit it with some heat.
Torch the bolthead 'till it's redhot. Let it cool, repeat.
Then use a breaker bar and hammer the hell out of it.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #140 of 516 Old 09-18-2014, 07:27 PM Thread Starter
aroundincircles
1989 XJ Cherokee
I tried the impact wrench, and it did nothing. I have beaten on it so hard I may just buy new shackels. I am gonna tear these ones up.
89 Cherokee
post #141 of 516 Old 09-18-2014, 07:57 PM
Motorcharge
Motorcharge's Avatar
PB Blaster is garbage. 50/50 acetone and auto trans fluid. Works 90% of the time. Just bear in mind it's entirely possible the bolt and nut have basically welded themselves together. But if you're not worried about the old leaf springs torch the bushing and just hit the bolt with a grinder between the shackle tabs. Don't bother with a sawzall, they don't go through those hardened bolts for ****.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #142 of 516 Old 09-18-2014, 08:59 PM Thread Starter
aroundincircles
1989 XJ Cherokee
This is the first and only time i've had a problem. I actually had bolts I forgot to spray before I started the work, couldn't get off sprayed, waited 20 minutes, and then had no issue getting them off. I'm a convert.
I'm going to take it to a tire shop, see if they cannot get them off for me.
89 Cherokee
post #143 of 516 Old 09-19-2014, 05:08 AM
LKWJEEPER
2009 KK Liberty
The nut isn't turning at all? Can you hit the other side with a BFH? Also I think I used my ratchet on the other side and held a locking vise grip on the nut. Seemed to work for me.
post #144 of 516 Old 09-19-2014, 08:22 AM Thread Starter
aroundincircles
1989 XJ Cherokee
Bolt spins if I don't have something holding the other end, but I put my socket on one side, and my impact wrench on the other and just went at it until it got so hot that it started to smoke a little (PB blaster burning)
89 Cherokee
post #145 of 516 Old 09-19-2014, 10:24 AM
LKWJEEPER
2009 KK Liberty
Sounds like the bolt has rusted to the inside of the sleeve of the leaf spring. Worst case is to just get new shackles and hardware right? Looks like you have it off the Jeep
post #146 of 516 Old 09-19-2014, 05:51 PM Thread Starter
aroundincircles
1989 XJ Cherokee
Finally got free shackels. They never got mine off, they used a 1200ft/lb impact wrench to no effect. So the shop traded me, my rear springs with shackels for a new set.
89 Cherokee
post #147 of 516 Old 09-19-2014, 06:19 PM
LKWJEEPER
2009 KK Liberty
Awesome!! Glad u got it resolved
post #148 of 516 Old 09-20-2014, 12:36 PM Thread Starter
aroundincircles
1989 XJ Cherokee
finally got the bushing sleeves out. Got the bushings out last night, but left the sleeves in since I thought I might need them with the new bushings... oh how wrong i was, so has to use a sawzall to cut them down a little so I could fold them in and pop them out. only problem is I don't have a sawzall, so had to go over to my dad's to use his.
89 Cherokee
post #149 of 516 Old 09-20-2014, 01:33 PM
DunmerBoy
DunmerBoy's Avatar
Almost done then??
COTM October 2014
DunmerBoy is offline
post #150 of 516 Old 09-20-2014, 01:36 PM Thread Starter
aroundincircles
1989 XJ Cherokee
Originally Posted by DunmerBoy View Post
Almost done then??
I am hoping tonight. Today is family time.
89 Cherokee
