4hi and 3 - 2/1 gear - JeepForum.com
post #1 of 6 Old 12-19-2008, 02:32 PM Thread Starter
mk34
Is it okay to use 4 wheel high with 3rd gear or 2-1?
mk34 is offline
post #2 of 6 Old 12-19-2008, 03:45 PM
csouers
csouers's Avatar
It depends. We really need more info. I'm assume your transfer case for 4wd has 2wd-4wheel high-neutral-4 wheel low. If that is the case, any tranny selection will work but you shouldn't really be going that fast if you need 4wd. With your transfer case, the np-231, you only have locking 4wd which if used on dry concrete can cause the drivetrain to bind up and break.
Do us a favor. Please fill out your jeep info in your profile and change the engine to an I6. They didn't make V6's for xjs.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #3 of 6 Old 12-19-2008, 03:52 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Well, they did put v6's in XJ's just not in 99.
xjfever is offline
post #4 of 6 Old 12-20-2008, 03:27 PM
csouers
csouers's Avatar
Hrmm. Didn't know that. Was this in the mid to late 80's?
csouers is offline
post #5 of 6 Old 12-20-2008, 03:48 PM
dudeinajp
dudeinajp's Avatar
84-86 2.8L V-6
dudeinajp is offline
post #6 of 6 Old 12-20-2008, 04:39 PM
mud-dog27
if you have a NP242 you should be fine in 4WD full-time using 3&1-2 thats all i use in winter around here as MTs and ice dont go well when you add brakes to the equation.....i just down shift accordingly to my speed
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
mud-dog27 is offline
Transmission not staying in gear, cant shift into gear Jakeman17 MJ Comanche Technical Forum 4 02-08-2010 12:51 PM
Gear problems...troubles going into gear smallwhitexj XJ Cherokee Technical Forum 2 01-09-2009 12:33 AM
Speedo gear change! 95$ for 32 gear Xjdude XJ Cherokee Technical Forum 7 03-03-2004 10:00 PM
gear oil rlc588 XJ Cherokee Technical Forum 1 07-17-2003 12:30 PM
Which gear for 33s, 4.11 or 4.56?? Bear549 XJ Cherokee Technical Forum 14 07-16-2003 08:21 PM
