Tipm - JeepForum.com
post #1 of 6 Old 10-20-2021, 04:38 PM Thread Starter
Gmck1801
Tipm
Recently I purchased a 08 wrangler unlimited and when I crank it up the wipers come on and the lights wont turn on also the turn signals wont work either. Could this be the TIPM? If so will a tipm from any Jeep, dodge or Chrysler wont in mine?
Gmck1801 is offline
post #2 of 6 Old 10-21-2021, 12:01 PM
cranbiz
cranbiz's Avatar
Disconnect the negative battery terminal for about 5 minutes and then reconnect it. Make sure that the 10 mm nuts that release the clamps do not have any wire terminals connected to them.
The symptoms you describe could be a voltage issue (loose connection, battery going bad, etc) or the TIPM. The disconnect should reset the TIPM and if it's simply a computer glitch, it will go away. You need a Wrangler specific TIPM, not anyone will do. It also has to be the right generation. A TIPM from a 12 may not work in a 08. If you go the TIPM route, buy one based on the part number of yours.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 6 Old 11-24-2021, 06:32 AM
JKLINGO
TiPM / Clock Sping Multifuntion
OK lost my headlights, Wipers and Signals and dome light. Pulled TIPM sent to TIPM rebuilders , The found nothing wrong with TIPM, Replaced Multifunction switch, still no success, replaced wiper switch, still nothing,
replaced clock spring. still nothing. Disconnected battery numerous times. Re-seated TIPM connections numerous times. ocationally things will work for short period of time.
When I disconnect the multifunction switch headlights an wiper are on constantly.
Any help as what to try next on my 2008 JKU rubicon
JKLINGO is offline
post #4 of 6 Old 11-24-2021, 07:16 AM
222Doc
222Doc's Avatar
no codes. I would be looking at grounds. meaning Not to just look but take off and clean it while looking.
222Doc is offline
post #5 of 6 Old 11-24-2021, 10:21 AM
JKLINGO
Went over all grounds and cleaned. Forgot to mention. Battery at 12.5 v and passes load test. No recent modifications. I do get
Codes
U0118B & U0118A Lost Communication with AFS Module left and Right
B1630 & B1620 Right and left low beam control circuit high (These I believe gave been on for two years after installingOracle LED Headlights
U0186 and U0184 Lost Communication with Radio and Factory amp. These have been on for years after aftermaket stereo intsall.
Today I turned key on the gather codes. Lights and wipers com on intermittently
JKLINGO is offline
post #6 of 6 Old 11-30-2021, 01:48 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Makes me wonder if your stereo is wired correctly, and or backfeeding through a ground, especially if it doesn't think its connected
Hoss
I used to be a people person, until people ruined it...
JoonHoss is offline
