Sunrider Besttop extremely difficult to close - JeepForum.com
post #1 of 7 Old 07-27-2008, 09:07 AM Thread Starter
paullorimeier
Guest
We have a 98 Wrangler with a Sunrider Besttop and I have a very difficult time getting it to close. The section that flips back is where I have the problem during closing. I can not get the support bar into the locking position. It seems that it should be much easier. Am I doing something wrong, or is it just common with this type of top? If so, I need to buy another soft top because I don't want to work that hard.
paullorimeier is offline
post #2 of 7 Old 07-27-2008, 11:12 AM
Lumpymayo
Lumpymayo's Avatar
Are you talking about the piece that is directly above the windshield? There are 2 latches there, both of those latches split in half making it easier to get them in the hole, then when in the hole pull the other one down to fully latch it. It's hard to explain.
Lumpymayo is offline
post #3 of 7 Old 07-27-2008, 01:22 PM Thread Starter
paullorimeier
Guest
No, I mean on the sides near the middle of the passenger and driver side window. It is hard to explain! When you put top down you take out windows, pull out the pin above the passenger and driver side window, and then undo the windshield latches. The part that is hard when returning to the upright position is the bar that is eventually above the side windows. It has to get pushed back into that pin hole. I hope this helps. Thanks for your help!
post #4 of 7 Old 07-27-2008, 03:56 PM
Avian
I know what youre talking about. Mine does it too. But only on my passenger side.
Sometimes I can just man handle it, other times I have to latch the windshield first. I always find it easier to do it if I start with the hard side first though.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #5 of 7 Old 07-27-2008, 04:19 PM Thread Starter
paullorimeier
Guest
The top came with the jeep so we have no instructions. I am just wondering if there is some sort of adjustment to make this procedure less painful!
post #6 of 7 Old 07-28-2008, 06:19 AM
Avian
Nope, its just stiff.
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #7 of 7 Old 07-28-2008, 12:35 PM
rikkards
rikkards's Avatar
I have a new one as well and can kind of relate. I find you have to pull HARD on it to get it to snap into place. But it will. The big complaint I have is the top will pop out of the part that attaches to the windshield every once in a while when putting the top up or down (not while it is up). It supposedly snaps into place but I have not got it to snap. The worst part of installing it was getting the rear bow bolted to the right rear bracket, it was like the bow was about a half inch too long so getting it lined up with the whole was a major pain.
I believe the instructions are available at Quadratec's website that came with it.
By the way first post. I have been lurking here for the last month. Very informative.
rikkards is online now
BestTop - Sunrider: can't get winshield header to hook into windshield! jblaiz TJ Wrangler Technical Forum 2 04-06-2009 10:49 PM
BestTop - Sunrider: can't get winshield header to hook into windshield! jblaiz JK Wrangler Technical Forum 1 04-06-2009 02:13 PM
4lo extremely difficult?? kis86 TJ Wrangler Technical Forum 13 03-16-2009 03:29 PM
besttop softdoors..work with sunrider top? distortedtj TJ Wrangler Technical Forum 1 09-08-2008 02:51 PM
Steering is extremely difficult Mr. Tobes YJ Wrangler Technical Forum 23 06-04-2006 07:18 PM
