stock steel 17 inch rims - JeepForum.com
post #1 of 7 Old 05-22-2019, 03:00 PM Thread Starter
Kluk Ztopolovky
Hello , has anybody out there installed larger size tire on the stock steel rim ? I am thinking maybe 255 /70/17 or even 265/70/17 should work just fine without any lift. I just wish to get slightly wider tire but I can not lift the Jeep because I wouldn't fit under the underground garage door. Thanks.
Kluk Ztopolovky is offline
post #2 of 7 Old 05-22-2019, 05:19 PM
RubiconFreedom
RubiconFreedom's Avatar
2017 JK Wrangler
Reference: Jeep Wrangler Wheel 17" Winter / Off-Road?
http://theroadchoseme.com/tire-selec...o2-all-terrain
Quote for the article: "BFGoodRich KO2 All Terrain in 34◊10.5r17"
Semi-Retired Sr. Mechanical Assembler & Sr. Quality Assurance Inspector for Aerospace Industry
RubiconFreedom is offline
post #3 of 7 Old 05-22-2019, 05:45 PM Thread Starter
Kluk Ztopolovky
Rubicon is higher
thanks, great set of tires but I believe the Rubicon is bit higher than the basic Sport model which I have purchased , good luck with your trip sir
post #4 of 7 Old 05-23-2019, 03:49 AM
RubiconFreedom
2017 JK Wrangler
Just wanted to follow with my comments of yesterday cause I ran out of time while I was here earlier. According to your topic heading, you said 17'' steel wheels. Jeep only manufactures those 17 winter steels wheels. So are you referring to those steels or the stock 16'' steel wheels thats more accustom on the sport models. Our current wrangler has 16'' stylized steel wheels with 31'' Bridgestone tires. Over the last 2 years, this wheel and tire combo has not been very comfortable.
I think if you're wanting the 17'' wheels, make sure they are the alloy wheels and not the steels. As for vehicle height, the only real height difference would be what accessories like hard to hard doors would determine what coil springs have been used on the jeep. Check your sports coil setup, you're looking for the tags attached to these coils. Tag numbers could be 17AC/56AA as this is a basic setup. Rubicon coil spring tags could read: 18AB/58AA which would offer a stiffer ride and more of a boost.
Otherwise a stock sport could handle 33's (measure 32.6 etc) without any lift. Just depends if you're talking about the 16'' steels or the winter 17'' steels.
As for the link, that's not my jeep or our travels.
post #5 of 7 Old 05-24-2019, 03:52 PM Thread Starter
Kluk Ztopolovky
stock steel rims on Wrangler Sport JL
Hello , well the new Wrangler Sport basic model comes with 17 inch steel rims as you can see here on the official Jeep www. I think I will keep them for some time and later I may replaced them with aluminum alloy rims and slightly wider tire. Thanks for your advice.
https://www.jeep.ca/en/build-and-pri...1#step=colours
https://www.jeep.ca/en/build-and-pri...activeTab=cash
post #6 of 7 Old 05-25-2019, 02:52 AM
RubiconFreedom
2017 JK Wrangler
According to your topic title, there was no mention of the jeep being a JK or JL and I wasn't aware the the new JL has 17's simply because we have no desire to ever want a JL wrangler.
post #7 of 7 Old 05-25-2019, 05:29 AM Thread Starter
Kluk Ztopolovky
thanks
thanks , I hope sir your desires not to ever own a JL are fulfilled and I will make sure I will enjoy mine
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3856 07-28-2019 09:18 AM
3-4 Inch Bilstein 5100s on a 2.5 inch lift? Oblah WJ Grand Cherokee Forum 2 07-26-2018 07:24 PM
2010 XK limited 5.7 all stock, 18inch rims arielxkjeep Tires & Wheels 0 04-24-2018 12:48 PM
How did I gain 1 inch of rear lift? wranglertec WJ Grand Cherokee Forum 3 04-23-2018 01:33 PM
Call me stupid, tell me I didn't search the threads-too bad I did. AAl vs RLS HornedFrogHooah XJ Cherokee Technical Forum 23 04-24-2010 12:33 PM
