Rear seat bolts - how to prevent them from rusting when reassembling them - JeepForum.com
 3Likes
  • 1 Post By cranbiz
  • 2 Post By 1Old_Crow
post #1 of 4 Old 07-29-2021, 11:45 PM Thread Starter
amped
I took out the rear seats and the bolts are pretty rusted at the tip. I will put them back in so I won't loose them and also to prevent water/debris from coming thru the bolt holes. What to use to prevent the bolts from rusting?
I'm afraid whatever I put on the thread of the bolts will probably be removed when they get turned thru the bolt holes. Another thought I had was to paint them from the underside of the wrangler but the thing is I can't paint all of them. Some of them are not accessible as they are blocked.
Anyone got some ideas for me?
TIA
amped is offline
post #2 of 4 Old 07-30-2021, 07:10 AM
cranbiz
cranbiz's Avatar
Never seize. That stuff gets everywhere and doesn't come off.
JD Blaine likes this.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 4 Old 07-30-2021, 07:48 AM Thread Starter
amped
So no anti-seize. Another thought is maybe using plastic bolts? I just need to plug the holes so nothing will get in.
amped is offline
post #4 of 4 Old 07-31-2021, 06:29 PM
1Old_Crow
1Old_Crow's Avatar
Never seize, anti-seize...same thing. Why would you not use something designed for the exact job you're doing?
Shark_13 and cranbiz like this.
Wally Crow
ASE Master Auto Tech(ret)
'03 TJ Sahara
"Roads? Where we're going we don't need roads."
1Old_Crow is offline
