need info on 3" body lift - JeepForum.com
post #1 of 4 Old 11-04-2008, 07:48 PM Thread Starter
southernss
southernss's Avatar
the jeep i just bought has a 3" b/l as well as suspension lift which i believe is 3" also. i am deabting of just buying a 1" or even 1.25" b/l to replace the 3". the main reason for this because i believe it would look better but also when the lift was done theyhad to notch out the hole in the firewall where steering shaft come through and it is really annoying me. was the opening of this hole necesary on the 3" b/l. know the rubber grommet is no longer in there and i dont like that you can just see right through it. i believe i can bend the piece back that was cut to be able to reinstall a new grommet if putting a 1.25" lift on would rectify this problem.
southernss is offline
post #2 of 4 Old 11-04-2008, 07:59 PM
bucks11
Good call....I'd ditch the 3" BL and go with a 1.25
IMO I don't see a need for such a big BL...
bucks11 is offline
post #3 of 4 Old 11-04-2008, 08:01 PM
xtreampyro
dont know about the hole but i would deff switch out the bl
02 TJ 4.0, 6" Clayton LA's, HP D44 Eaton, Sterling 10.25 Detroit, SniperFab Flares/Rock Sliders
xtreampyro is offline
post #4 of 4 Old 11-04-2008, 08:16 PM Thread Starter
southernss
southernss's Avatar
i have 35's on it right now do you believe i will have rubbing or clearance issues going with the 1.25?
thanks
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
Body Lift Info Ohenry13 YJ Wrangler Technical Forum 1 07-11-2007 10:01 AM
body lift info sk80soarus YJ Wrangler Technical Forum 9 08-16-2006 12:09 PM
wanted: 3" body lift info and pictures 92 RED YJ IN NJ YJ Wrangler Technical Forum 1 10-11-2001 05:45 PM
