Matching Tires - JeepForum.com
 7Likes
post #1 of 16 Old 02-27-2019, 04:22 PM Thread Starter
Nadelius
Nadelius's Avatar
Matching Tires
I bought a YJ with very nice aftermarket rims... but only 4 of them. I can't find the match to get my missing spare. Any ideas how I might get my elusive 5th rim? Or should I just buy 5 cheapos and pawn the 4 nice ones?
Nadelius is offline
post #2 of 16 Old 02-27-2019, 04:45 PM
mukluk
mukluk's Avatar
If you could share the identity of your aftermarket wheels or a good picture of them, somebody might have an idea where to get an extra.
TheBoogieman likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 16 Old 02-27-2019, 06:07 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Nobody ever said the spare wheel MUST match the other 4. And if it bothers you, just get 1 cheapo steel wheel and matching tire and throw a tire cover on it.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 16 Old 02-27-2019, 06:18 PM
biffgnar
biffgnar's Avatar
Exactly, I actually have a 5th Raceline beadlock, but the spare on the back of my jeep is an OEM wheel.
biffgnar is offline
post #5 of 16 Old 02-28-2019, 12:10 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
I'm sure the company made more than 4. Post a pic.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Originally Posted by Jerry Bransford View Post
I'd rather knock myself unconscious, cut a finger off, poke my eye out with a sharp stick or be forced to go back to work than install anything made by Rusty's.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/BM brakes
99' XJ on 33s. #18
TheBoogieman is offline
post #6 of 16 Old 02-28-2019, 07:01 AM
2jhanna
As long as the overall height of the spare tire is the same, or even very close, it doesn't matter what wheel/tire combination you use for a spare.
Even if you have alloy 17" wheels, your spare can be a steel 15", overall tire height is what important.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #7 of 16 Old 02-28-2019, 08:29 AM
biffgnar
biffgnar's Avatar
And using a small wheel and even a slightly smaller tire means carrying less weight. My 17" Raceline beadlocks plus 35x12.5 MTRs are about 110 pounds each. An OEM 15" wheel plus a 33x10.5 KM2 weighs probably 30-40 pounds less. Would I drive hours on that smaller tire at highway speeds? Probably not. But combined with having OBA and carrying a plug kit, that tire will get me where I need to go in an emergency.
The one issue using a smaller wheel size spare can present is if you do a big brake kit upgrade the smaller wheel may not fit over the bigger calipers. I have the 17" Vanco kit which uses 54mm dual piston calipers from a Ram 1500. If I get a front flat that can't be plugged it requires changing two tires (i.e. moving one of the tires from the rear to the front and putting the spare on the rear).
biffgnar is offline
post #8 of 16 Old 02-28-2019, 08:51 AM
2jhanna
Originally Posted by biffgnar View Post
And using a small wheel and even a slightly smaller tire means carrying less weight. My 17" Raceline beadlocks plus 35x12.5 MTRs are about 110 pounds each. An OEM 15" wheel plus a 33x10.5 KM2 weighs probably 30-40 pound less. Would I drive hours on that smaller tire at highway speeds? Probably not. But combined with having OBA and carrying a plug kit, that tire will get me where I need to go in an emergency.
In the 11 years that I've had my TJ, I've never taken it wheeling or a road trip (I know, what a waste). It's just my run-around-town vehicle, I have garage space for it and haven't had the top or full doors on in 8-9 years. A few years ago I decided I didn't even need the spare, so I removed it all together. I haven't missed it or it's weight at all.
Dr. Internet and TheBoogieman like this.
jhanna
denton county, tx
2jhanna is offline
post #9 of 16 Old 02-28-2019, 09:24 AM
TheBoogieman
Distubed Jeepaholic
18 Jeeps and I've never needed a spare either. I keep a spare because that's my luck. Murphy's Law.
99' XJ on 33s. #18
post #10 of 16 Old 02-28-2019, 09:54 AM
2jhanna
I'm sure I'm gonna jinx my self because in the next month I have 5000+ miles of road trips planned in my truck f150 and tahoe. But I can't actually remember when I've had to change a roadside flat on any vehicle, in at least the last 35 years (at 65 years old, my memory starts fading past that point). Now, don't get me wrong, I've had nails and such in tires which leak, but always able to plug or address in my driveway at home.
Now, each of my grown sons have had a hiway blowout due to unavoidably hitting debris, and needed to use their spare. I also wouldn't consider taking a road trip without a spare.
jhanna
denton county, tx
2jhanna is offline
post #11 of 16 Old 02-28-2019, 10:15 AM
biffgnar
biffgnar's Avatar
I've absolutely considered losing the spare. With this jeep I think the only time i used the spare was one day when checking pressure a tire spit the entire valve. Not real hard to carry a few replacements of those in addition to a plug kit though. I have had highway blowouts on other vehicles though. And on the trail I never want to be that guy. The smaller wheel/tire combo is the compromise I've made with myself.
biffgnar is offline
post #12 of 16 Old 03-01-2019, 12:44 PM Thread Starter
Nadelius
Nadelius's Avatar
If I knew the logo, I might have been able to find one. Note that these were polished metal, which doesn't match the body, so I plastidipped them. The indents on the outer most edge of the rim (before it turns verticle) was shiny black.
15514692142333370873518672591386_1551469231928.jpg   1551469246001449722467443011095_1551469266616.jpg
Nadelius is offline
post #13 of 16 Old 03-01-2019, 01:20 PM
mukluk
mukluk's Avatar
The cap is MB Motorsports, the in-house brand from Discount Tire.
TheBoogieman and Bdajeep like this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #14 of 16 Old 03-01-2019, 02:48 PM
TheBoogieman
Distubed Jeepaholic
https://www.discounttiredirect.com/w...ands/mb-wheels
99' XJ on 33s. #18
post #15 of 16 Old 03-02-2019, 04:29 AM Thread Starter
Nadelius
Nadelius's Avatar
Yeah, I see them now... discontinued 😞
It's a shame, because now that I painted them, I like them. Lol
Nadelius is offline
Time to save on Tires - Mickey Thompson & Dick Cepek Promos! CARiD CARiD.com 0 02-25-2019 05:51 AM
temporarily swapping my 35in mud tires for 32in tires on highway Muddzy Tires & Wheels 8 01-19-2019 09:56 AM
14 Sahara unlimited w/ 18” rims Lokotony Tires & Wheels 2 11-07-2018 03:46 PM
Buying New Tires..Need a lil help! mason0929 Tires & Wheels 2 09-05-2018 06:18 PM
Get exceptional all-terrain performance with AMP tires for JKs CARiD CARiD.com 0 07-31-2018 07:30 AM
