In which I purchase my first Jeep - '05 LJ - JeepForum.com
post #1 of 11 Old 02-12-2015, 09:04 AM Thread Starter
gallamine
Just a friendly post to announce my entrance into the jeep family. Got a 2005 manual LJ with 110,000 miles recently. I'm quite happy with my purchase and looking forward to trouble shooting all of my wowes.
Speaking of, the first thing I need to figure out is why it has a "whine" during acceleration. The whine is:
  • Tied to acceleration.
  • Happens at lower speed < 45 mph
  • Isn't more obvious when hanging head out the window
  • Isn't obvious when sitting on the hood and listening
  • Dies down when I put in the clutch
  • As soon as I put my foot on the accelerator it starts
Here's a link to a video showing the sound and the RPMs.
I shift through 1st, 2nd and 3rd in this video and put in the clutch several times.
My current theory is that it's either a) clutch or b) pinion related. Any thoughts?
gallamine is offline
post #2 of 11 Old 02-12-2015, 09:44 AM
mdm
Farm Wheeler
Can't watch your video here. Just understand that these rigs are noisier than your typical passenger car. There is less sound insulation and the transmission and transfer case aren't built with as much concern about mechanical noise as your typical passenger car. The transmission and transfer case are sitting right next to your legs and both of them contribute a lot of noise to the mix, to include gear/bearing whine.
Welcome to the forum and the world of Jeeps!
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 11 Old 02-12-2015, 10:04 AM Thread Starter
gallamine
Thanks MDM. The video is marked as public. Not sure why it doesn't play. I've never driven a Jeep with this particular sound and my brother-in-law, with a '06 Rubicon LJ, thought it sounded odd. Just wanted to stay on top of the maintenance and keep small things from becoming big things. Still getting used to the idea of "anything is fixable."
post #4 of 11 Old 02-12-2015, 10:12 AM
mdm
Farm Wheeler
Originally Posted by gallamine View Post
...The video is marked as public. Not sure why it doesn't play...
Where I am some things don't get through.
mdm is offline
post #5 of 11 Old 02-12-2015, 03:46 PM
digitalcox
digitalcox's Avatar
Congrats on the Jeep purchase. There have been times that I wish I went with a LJ. Have fun with it!
It might not hurt to change out the fluids (diff, transmission, transfer case) when you get a chance to go under the Jeep to rule out one issue with the whine that is coming from the video.
Also, some additional reading from Superior's website:
What is this whirring noise?
Whirring noise only while decelerating at any or all speeds is most likely caused by bad pinion bearings or loose pinion bearing preload, and almost never by bad ring and pinion gears.
A howl or whine during acceleration over a small or large speed range is usually caused by worn ring and pinion gears or improper gear set up.
Rumbling or whirring at speeds over about 20 mph can be caused by worn carrier bearings. The noise may change while turning.
Regular clunking every few feet may indicate broken ring or pinion gears.
Banging or clunking only on corners can be caused by broken spider gears, lack of sufficient positraction lubrication, or worn positraction clutches.
Rumble while turning may indicate bad wheel bearings.
A steady vibration that increases with the vehicle’s speed can be caused by worn u-joints or an out of balance driveshaft.
Clunking only when starting to move or getting on and off the gas might be loose yokes, bad u-joints or worn transfer case or transmission parts.
Justin
2004 Jeep Wrangler l 1946 Willys CJ2A l 1988 BMW 325 l 2009 Triumph Thruxton
digitalcox is offline
post #6 of 11 Old 02-13-2015, 12:56 PM
mike134
first thing I would do is check the air system. If it was upgraded to an aftermarket cold air intake, this can cause a loud suction whine during acceleration. If this is the case, it is a sought after 'desired' whining noise.
It somehow sounds like a super charger though. Presumably it is not...
I would definitely be checking out the state of the fluids in the engine, transmission, diffs, and transfer case though. Doesn't take much time, and could save you a ton of money.
mike134 is offline
post #7 of 11 Old 02-13-2015, 01:59 PM
JeepJeffW
JeepJeffW's Avatar
That reminds me of the sound my buddies stock car (Barracuda) made when driving it normally. That was many years ago. Like the drive train is really "tight." He never did anything to it except the one time he blew out the rear drive shaft and the shaft flew into the tranny rendering it useless. But yeah, check all the fluids - and the drive train for play while your under it.
"The government cannot give to anybody anything that the government does not first take from somebody else. You cannot multiply wealth by dividing it."
~~~~ Dr. Adrian Rogers, 1984
JeepJeffW is offline
post #8 of 11 Old 03-30-2015, 04:09 PM Thread Starter
gallamine
As an update to this thread, I removed my rear-driveshaft and drove the vehicle around. The whine was still present, so whatever it is, it is not the rear-end.
post #9 of 11 Old 03-31-2015, 09:59 AM
329892 - Deactivated
Guest
I want video of the "sitting on hood at 45mph" !!
But I think I hear it change pitch when you shift / change rpm indicating the sound is engine, not driveline related. And it is tough to tell but it sounds mechanical. Could be transmission since the front half of the transmission changes speed when you shift too.
Old trucks with straight cut gears made that sound too.
329892 - Deactivated is offline
post #10 of 11 Old 03-31-2015, 07:49 PM Thread Starter
gallamine
Yeah, hood up, brother-in-law perched on the bumper, driving around a parking lot. Thankfully it was a lot slower than 45 mph!
The sound is related to acceleration - at low speeds in 1st or 2nd gear I can gently put my foot on the accelerator and the sound starts, when I lift my foot off it stops. The pitch changes with RPM. It definitely sounds mechanical to me - e.g. not coming through radio or CB. I've driven an '06 LJ Rubicon that didn't make that sound. Someone suggested a clutch bearing.
post #11 of 11 Old 04-05-2015, 12:19 PM
1991YJisLife
Are you sure it's not the radio? If I am playing music from my phone and charging it at the same time there is a noticeable whine that increases with the engine rpms. If the radio is hooked up poorly it could possibly be your problem. You could try pulling the fuse for the radio and see of it goes away
1991YJisLife is offline
lj , new buyer , unlimited , whine
