Holes in my hood - Page 3 - JeepForum.com
 5Likes
post #31 of 45 Old 05-03-2016, 10:48 PM
Shark_13
Originally Posted by TheDonk View Post
Is it just me or do those look like shop vac attachments?
Yep, it blows and sucks!
Shark_13 is offline
post #32 of 45 Old 05-04-2016, 12:16 PM Thread Starter
jeeper_LJ38
That's the problem I don't wan try and match paint and take out screws and scratch paint if there is a way I can fill it or put something in its place I'd rather do that
jeeper_LJ38 is offline
post #33 of 45 Old 05-04-2016, 02:39 PM
avatr
2012 KK Liberty
IMO:
throw on a cheap light bar... just know you might get reflection from the hood.
use black or chrome bolts to fill in the holes.
replace the cowl.. paint it satin black, plastic dip or rhino type lining
2008 JK Rubicon - sold
2012 KK Liberty - sold (sadly)
avatr is offline
post #34 of 45 Old 05-04-2016, 03:06 PM
14Sport
14Sport's Avatar
First thing I would do is remove them so you have an idea of what you are dealing with underneath. A couple of small drilled holes per vent? A 3" diameter circle? A 4"x6" rectangle? Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 and xxdabroxx like this.
My observations are based on my experiences...YMMV.
14Sport is offline
post #35 of 45 Old 05-12-2016, 08:19 AM
Kuntryboy816
Kuntryboy816's Avatar
I feel like this needs to be my forum signature!
Kuntryboy816 is offline
post #36 of 45 Old 05-12-2016, 09:11 AM
14Sport
14Sport's Avatar
Hahaha...have at it.
14Sport is offline
post #37 of 45 Old 05-13-2016, 07:04 AM
Ross
OP I would think twice about putting a light strip on your cowl. I would think glare off the hood would be terrible.
As far as the vents. If the holes are just bolt holes put some black screws in them. If they are bigger holes I would just get lower profile vents.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is offline
post #38 of 45 Old 05-17-2016, 10:18 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
This.
You need to know what you have, and are dealing with first.
I agree on not wanting to try and match paint, but if you only have a couple tiny, evenly spaced holes, I you might find that you can put a couple cap screws or carriage bolts there (and painted with touch up paint) which will blend in so well you won't even notice.
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #39 of 45 Old 08-31-2016, 01:09 PM Thread Starter
jeeper_LJ38
Tires
Looking for some 31 inch all terrain tires and rims or just tires for my LJ. Don't have the money for a lift and tires and have no tread left on my tires. So looks like I'm buying tires. I currently have 17 inch rims
post #40 of 45 Old 08-31-2016, 01:27 PM
biffgnar
biffgnar's Avatar
While this is your thread so maybe not a hijack, you probably should start a new thread with appropriate title if you are looking for discussion of this.
biffgnar is offline
post #41 of 45 Old 08-31-2016, 02:08 PM
arbakken
2015 JK Wrangler
get some 32" takeoffs from a new rubi
arbakken is offline
post #42 of 45 Old 09-02-2016, 05:24 AM
wkndwarrior
wkndwarrior's Avatar
That's what I did....., CL, spent less on 2015 rubi wheels and tires w less than 1000 miles than I would have on just tires. And I like them better than the 2012 rubi's I had.
wkndwarrior is offline
post #43 of 45 Old 09-02-2016, 08:39 AM Thread Starter
jeeper_LJ38
Don't you need adapters if you use the new jeep wheels. I thought it was a different bolt pattern
post #44 of 45 Old 09-02-2016, 09:20 AM
arbakken
2015 JK Wrangler
You already have 17s, you just need this: http://www.ksl.com/?nid=218&ad=40128...5r17&ad_cid=10
arbakken is offline
post #45 of 45 Old 09-02-2016, 09:30 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Just to be clear, the new JK does have a different bolt pattern than your TJ.
If you just buy used 17" tires, they'll work with your current 17" rims
If you buy JK 17" take-offs as a set (wheels and tires), and want to run them as-is, you'll need adapters
Hoss
JoonHoss is offline
