Help me with a decision! - JeepForum.com
View Poll Results: Wrangler or Wrangler Unlimited
Wrangler 2 50.00%
Wrangler Unlimited 2 50.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
post #1 of 6 Old 09-02-2015, 02:22 PM Thread Starter
corndawg665
I'm getting back into a Jeep after not having one for two years. Currently I'm twisted between purchasing a two door manual, or a Wrangler Unlimited with an automatic. I don't do any off roading. However I want to hear from you guys and your experiences. I will be getting something 2010 and newer so keep that in mind. Thanks for your input!
corndawg665 is offline
post #2 of 6 Old 09-02-2015, 02:46 PM
beber
2005 WK
Are you single or do you have a family? Do you take a lot of long trips? Do you plan to do any towing? Is this going to be your primary vehicle?
2005 WK Limited with 2" BB
1997 Wrangler 4 cyl, unknown 3" lift and 33"
beber is offline
post #3 of 6 Old 09-02-2015, 05:11 PM Thread Starter
corndawg665
Yes, I'm single. It's replacing a Chevy Cobalt I currently use as my daily driver. I do plan to take long trips once a year, and either way I'm going to need the ability to tow if required.
post #4 of 6 Old 09-02-2015, 07:20 PM
222Doc
222Doc's Avatar
in 12 and up many changes. The auto in those is a lot better trans than the older. deeper first, less oD. handles a lot more torque(off road it is rather good.. The 3.6 has more power, early 3.6's had some head issue and extended warranties, though not sure if that goes forward.
222Doc is online now
post #5 of 6 Old 09-03-2015, 05:58 AM
rsurran
rsurran's Avatar
Not sure about the towing capability of the Unlimited but for long trips I would go with the bigger Jeep and automatic. I have seen Unlimiteds on the trails, basically being used the same as their 2 door cousins, in case you get the bug later on. Many are going to the automatics these days, even for off road use. If I buy another Jeep it will be automatic.
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
2013 JK Sport Black, Auto Trans, Bone Stock
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #6 of 6 Old 09-03-2015, 06:13 AM
PatyWagon
2015 JK Wrangler
I believe 2dr can tow 2000-2500lbs, unlimited is up in the 3000-3500lbs tow range. Don't quote me, check specs before buying. What are you towing?
JEEP WAVE from "MINION" ~ my 2015 Baja Yellow JK SPORT 2door
PatyWagon is offline
unlimited , wrangler
