Frost Problem Inside of Windshield - JeepForum.com
post #1 of 8 Old 02-09-2011, 08:37 PM Thread Starter
lacours
I live in Canada, and it gets COLD. I've been getting frost on the inside of my windshield, as opposed to the outside, for some reason. I don't like to simply scrape it off because it creates ice on my dash which eventually melts inside the vehicle. The engine takes a while to heat to the point where I can heat the windshield with air, and then it takes more time to wait for the thick frost to thaw out. It's really dangerous to drive away right after I start the Jeep because of terrible visibility.
Has anyone had this problem? Any solutions, such as a spray or something?
Thanks a lot,
Collin
lacours is offline
post #2 of 8 Old 02-09-2011, 10:32 PM
otr1952
I have had that happen other vehicles, windshield too cold.
maby put rainex on inside? I don't know!
Politicians are like Diapers, they get full of stuff and need to be changed frequently!
otr1952 is offline
post #3 of 8 Old 02-10-2011, 04:55 AM
BM20
mine does it in the late fall when it was starting to get cold when I still had the top off. it started as just moisture but as the temp dropped it turned to ice. maybe there is an air leak somewhere? I used to carry a small towel to lay on the dash to scrape it off instead of warming it up for 10 minutes. once i put a top on, it stopped.
RUBICON Tomb Raider #953
With a Few Extras...
BM20 is offline
post #4 of 8 Old 02-10-2011, 05:25 AM
Mark05059
your driving a tent basically... Leave more time and start your jeep before you leave. If it doesnt heat up quickly then it may need a warmer thermostat and a heater core flush. My 89 will drive you out of the jeep and it has no back window. Only takes about 5 minutes to warm up enough to thaw most everything out in the front...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 02-10-2011, 05:40 AM
nam1
nam1's Avatar
2010 JK Wrangler
Might be a dumb question but does it smell like antifreeze? I get condensation that freezes on the interior roof of mine and then drips once it melts.
________BOOM________
nam1 is offline
post #6 of 8 Old 02-10-2011, 08:06 AM
basssolow5
when it gets that cold, i like to put my top back on. its a little warmer
colorado jeep club member #730
stimulating the economy one part at a time!
basssolow5 is offline
post #7 of 8 Old 02-10-2011, 10:54 AM Thread Starter
lacours
I read through a similar thread and people were suggesting to leave the window open a crack. Apparently the water tracked in from your boots will end up on the windshield since it can't escape the vehicle. If you crack the window a tiny bit, the condensation escapes through there. Not a bad idea, I'm going to give it a try. The jeep can't get any colder anyway.
lacours is offline
post #8 of 8 Old 02-10-2011, 11:23 AM
Dogzilla
Run the AC compressor while you're diriving....It'll remove the moisture from the cabin. Also, don't leave the "recirc" button on.
Dogzilla is offline
windshield inside molding - where to buy? bryris YJ Wrangler Technical Forum 3 03-29-2008 02:24 PM
Windshield molding on inside of TJ VirginiaCountry TJ Wrangler Technical Forum 4 02-09-2008 09:17 PM
Frost Cracked Windshield and Replacement parts. Arecki_PL YJ Wrangler Technical Forum 22 02-08-2007 05:55 PM
Inside windshield molding? terrible TJ Wrangler Technical Forum 1 06-02-2005 09:06 PM
Ice Inside windshield... blowsox13 YJ Wrangler Technical Forum 14 01-19-2005 03:45 PM
