Death wobble - JeepForum.com
 1Likes
  • 1 Post By Red Rubicon
post #1 of 5 Old 03-21-2020, 12:46 PM Thread Starter
Finsfan46
Finsfan46's Avatar
Death wobble
I just recently bought a 2008 wrangler and have had nothing but problems. I'm still in the 7 day return period but I purchased the jeep about 1 month ago. 1st thing it was leaking oil which they replaced the oil pan gasket and front and rear crank seals. While doing this they noticed the starter had a stripped bolt and replaced that as well. Once I got the jeep back , after 2 weeks, it drove fine the 1st day. The 2nd day I went to start and it would not start. It would click once and then nothing. The lights and everything seemed ok so I thought maybe a bad starter or loose wire so I brought it back. They had it for 3 days and said no problem was found so I picked up the jeep. I have not had that problem again but yesterday when o was driving I had another issue. While going about 45 mph, the jeep started shaking or wobbling pretty bad. Once I slowed down to about 15 mph, it went away and has not done it again. Granted this only happened yesterday. I read this is normal for the jeeps and I read it needs front end work. Any suggestions?
Finsfan46 is offline
post #2 of 5 Old 03-21-2020, 12:59 PM
DougRz
Are the tires and suspension dead stock? Ie, is it lifted. Take some photos if you don't know. Of a tire with size clear. Of the suspension components from the front and side of the vehicle. Further replies here will be able to ask for more photos if needed.
Basically it's this: if it has been lifted poorly, you'll be suffering from death wobble until $ are thrown around to fix things. If it has been lifted well, probably a small tweak. If it's stock, probably a minor problem somewhere.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_) 03 auto, Ford 8.8, 4.88, Tru-tracs
DougRz is offline
post #3 of 5 Old 03-21-2020, 09:33 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
It's not normal for a Jeep, lifted or not. Main causes are loose track bar (or worn bushings), unevenly worn tires and front end isn't aligned properly.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #4 of 5 Old 03-22-2020, 12:06 AM
Geoskier9
Junior Member
Geoskier9's Avatar
Worn ball joints is also likely just looking at the age.
Geoskier9 is offline
post #5 of 5 Old 03-29-2020, 02:47 PM
Red Rubicon
The most common cause is poorly balanced tires.
222Doc likes this.
Red Rubicon is offline
