Wrangler 2016 - Decent Buy - JeepForum.com
post #1 of 7 Old 05-25-2021, 03:17 PM Thread Starter
varnco
Thanks for the forum.
First-time buyer of a Jeep Wrangler, but my dad did have a AMC Commando that I got ahold of every now and then when I was a kid. :-)
Anyhow, I am looking a buying a used 2-door Wrangler, for under $30K out the door, with these interior comfort items:
Power Locks, Power Windows, Backup Camera and Bluetooth stereo.
Other: Less than 75K miles
It seems that quite a few Wranglers are very limited on options that I mentioned above, that are in my price range. Is this to be expected?
Is there a list somewhere that tells you what accessory options were available with each model/year, so I know what to look for?
Also, I saw one the other day that had "t-tops"... I thought they stopped making those in the 80's because they leaked. Stay away from these?
Thanks.. all opinions/thoughts are good.
varnco is offline
post #2 of 7 Old 05-25-2021, 05:32 PM
222Doc
222Doc's Avatar
no T top but close "freedom panels". yes known to leak and they come with it standard on a hard top.
Biggest option you want is 3.73 gears that came with Max tow. Or stock its 3.21< hardly works on stock tires well. people want 35s, gears for that is 4.10-4.56. Street<<<< has nothing to do with off road.
Only way to get 4.1 stock, Rubicons and all autos even that was a option.
These newer jeeps once they get near high miles cost can get costly. since much is way to complicated for most to even change spark plugs...
222Doc is online now
post #3 of 7 Old 05-26-2021, 05:58 PM
Kev M
2016 JK Wrangler
Almost everything will have power door locks and windows.
But a backup camera was never available as an option on a JK so nothing till a 2018 JL will have that unless it's aftermarket.
I would think the U connect Bluetooth was available on most models.
If you're having problems finding these things (other than the backup camera), then I think it's your price range that's the issue.
Current Jeep: 2016 JKUS - My Mall/Beach/Dunes/Forest crawler - lightly modded
Kev M is offline
post #4 of 7 Old 05-26-2021, 09:55 PM Thread Starter
varnco
Thanks for the responses. These seem to be expensive and appear to hold their value.
Odd no camera till 2018, but I guess it's built for off-road, not backing up!
Anything to look for in a used one?
varnco is offline
post #5 of 7 Old 05-27-2021, 02:57 PM
cranbiz
cranbiz's Avatar
You can add one though. The 430 and 730 radios can support a backup camera. It just needs to be flashed, which can be cone with an OBD dongle and JScan on your phone.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #6 of 7 Old 05-27-2021, 04:14 PM
Kev M
2016 JK Wrangler
Yeah I thought about it for the first year or two, but the thought of having to pull up the center console and carpet and take apart the dash for access to the back of the NAV eventually convinced me to forget about it and get used to not having one again.
Then I rented a JLU the other week and was like are crap, I miss that.
Kev M is offline
post #7 of 7 Old 05-28-2021, 04:09 PM
JeepJeffW
JeepJeffW's Avatar
I've been looking at Wranglers for over a month and I saw one (1) 2door with a nav and backup system. I figured they installed it themself. Heck, with my butt sitting just about on top of the rear tire I really don't need the camera.
But I will make sure I have an auxiliary backup light since the rear factory lights suck. I always added them and had them switched so they would activate in reverse or by the switch for light when needed.
"The government cannot give to anybody anything that the government does not first take from somebody else. You cannot multiply wealth by dividing it."
~~~~ Dr. Adrian Rogers, 1984
JeepJeffW is offline
