Test drove lifted 2010 sway OMG! - JeepForum.com
 1Likes
  • 1 Post By cranbiz
post #1 of 15 Old 02-14-2019, 03:23 PM Thread Starter
poesdad
It had a trail master lift and 35s. When I moved the steering wheel back and forth it swayed so bad. Almost like it didn’t have shocks. Any ideas why? I just drove another one last night with the old man emu lift and it was nothing like that.
poesdad is offline
post #2 of 15 Old 02-15-2019, 06:35 AM
cranbiz
cranbiz's Avatar
Trailmaster is an entry level lift sold by Transamerica Auto (4WD/4WP). It's even lower cost than a Rubicon Express lift. The quality of that lift is nowhere near the quality of the OME lift. It was also probably missing things that a more expensive lift includes.
bharris68 likes this.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 15 Old 02-15-2019, 06:48 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Yep. Cheapo lift with no caster correction or proper axle centering vs quality lift with everything needed to correct the alignment issues that come along with any lift.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 15 Old 02-16-2019, 02:37 AM Thread Starter
poesdad
Interesting. I did not know they were that cheap. Good thing I posted this, thank you guys.
poesdad is offline
post #5 of 15 Old 02-16-2019, 04:59 PM Thread Starter
poesdad
Got a 2007 Sahara and it has a leveling kit and 33s on it now. Drives okay, but I will be lifting it and going 35s. I have had BDS full suspension lifts on both my 2011 Tundra and 2018 Ford F-150. Love them both. Obviously different style lifts and rigs, but I am curious what you guys suggest I run for a low cost 4”-4.5” lift for the Sahara that will not ride like that trailmaster, but I don’t need it to be crazy, since I won’t be hardcore wheeling it. That’s what my old YJ is for. Hoping to stay under $800 for the lift installed.
poesdad is offline
post #6 of 15 Old 02-16-2019, 05:41 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
That's way more lift than you need or really want on a JK and will totally blow your budget out of the water. When you go that tall on a JK, you start needing a bunch of extra things that don't come with a lift kit, like longer drive shafts.
You can run 35s on 2.5" of lift, and even then a quality kit is going to be more than your budget just for the parts. Old Man Emu, Teraflex and JKS are some of the better kits out there. Rubicon Express, Rough Country and Superlift are some of the lower end ones I'd avoid...
Then you're going to need to start looking at re-gearing the axles if you want to run 35s. The 3.8 and Sahara gearing is going to run like a complete dog on tires that size...
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #7 of 15 Old 02-17-2019, 10:40 PM Thread Starter
poesdad
So, would 35s for under this leveling kit?
poesdad is offline
post #8 of 15 Old 02-17-2019, 10:44 PM Thread Starter
poesdad
Can’t tell if this has 37s or 35s, but I would love mine to look like this.
https://www.quadratec.com/c/howto/truck-lite-rigid
poesdad is offline
post #9 of 15 Old 02-18-2019, 09:37 AM
cranbiz
cranbiz's Avatar
4.5" is way too much on a JK. Hell, I'm on 37's and 3.25" of lift and I wheel it hard. A 2.5" Teraflex spring lift will do what you want and within your budget. It's a budget lift that can be expanded on.
It's a great entry level lift, it will do 33's out of the box and 35's for off road if you go flat fenders. 35's fit fine if it's a pavement princess with stock fenders. The nice thing about this lift is you can buy it with shock extensions to reuse your factory shocks, buy it with Teraflex shocks or buy it with no shocks which will let you buy shocks that you like , something like Bilsteins, Rancho, Fox, etc.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #10 of 15 Old 02-18-2019, 12:26 PM Thread Starter
poesdad
Thanks for the info.. I will look at that. Can anyone tell what lift and size tires that one in the link is?
poesdad is offline
post #11 of 15 Old 02-18-2019, 12:39 PM Thread Starter
poesdad
So, would the 2.5” Teraflex Budget Boost work for what I want to do?
Is it the same height as their regular 2.5” lift kit with the supplied coils?
Looks like something I could do.
poesdad is offline
post #12 of 15 Old 02-18-2019, 12:41 PM
cranbiz
cranbiz's Avatar
No, really hard to tell. If I was to guess, 2.5-3.5" lift with BFG KM2's, probably 35's.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #13 of 15 Old 02-18-2019, 08:37 PM Thread Starter
poesdad
Any thoughts on the procomp 3.5” lift?
poesdad is offline
post #14 of 15 Old 02-19-2019, 12:24 AM Thread Starter
poesdad
Shoot!!! Disregard. I just watched a video of the terraflex 2.5” installed with 37s on it. Pics with 35’s look perfect. Pr
poesdad is offline
post #15 of 15 Old 02-19-2019, 08:20 AM
cranbiz
cranbiz's Avatar
This is a 2.5" Teraflex lift on 35's and then with 3/4" spacers and control arms added to run 37's.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
Sway bar links for lifted WK. voltquad WK Grand Cherokee & XK Commander Forum 3 10-21-2018 04:52 PM
Test drove a new Summit & High Altitude shudog WK2 Grand Cherokee Forum 3 04-03-2018 04:45 PM
Test Drove a 2018 JGC Summit today... andytschmid Grand Cherokee General Discussion 0 03-17-2018 08:50 PM
Test drove new JL Rubicon today! JMelton JL Wrangler Technical Forum 10 02-16-2018 05:22 PM
