Jeep Wrangler Unlimited 2-Door - Any Made Since 2006? - JeepForum.com
post #1 of 5 Old 08-18-2015, 10:01 AM Thread Starter
forthetimebeing
Greetings,
Has Jeep made any Wrangler Unlimited 2-Doors since 2006? I can't seem to find a definitive answer, the 4-door models keep showing up in searches.
Also, I understand the wheel base is 10 inches LONGER, but it is also wider, isn't it? Can't seem to find a number on how much WIDER it is.
Any help appreciated.
Steven
forthetimebeing is offline
post #2 of 5 Old 08-18-2015, 10:14 AM
jlb27537
No, unlimited 2 doors were 2004-2006 only. 2007 up unlimited were 4 door.
TJ:
Wheelbase = 93.4"
Overall length = 155.4"
Overall width = 66.7"
Overall height (soft top) = 70.8"
Track width = 57.8 - 58.5"
Turning diameter = 33.5'-36'
Curb weight = 3,092-3,832 lbs
Cargo capacity = 55.7 cu ft.
Fuel capacity = 15 or 19 gal (19 gal became standard during the 99 model year)
Towing capacity = 1,000 lbs 4cyl / 2,000 lbs 6 cyl
Ground clearance (at axle) = 8.7"-9.2" front / 8.6"-9.1" rear
Approach angle = 42.2*
Departure angle = 31.5*
Breakover angle = 22.3*
LJ:
Wheelbase = 103.4"
Overall length = 167-171.7"
Overall width = 66.7-68.2"
Overall height = 68.4" soft top / 70.9" hard top
Track width = 58.5"
Turning diameter = 36'
Curb weight = 3,730-3977 lbs
Cargo capacity =
Fuel capacity = 19 gal
Towing capacity = 3,500 lbs
Ground clearance (at axle) = 9.3" front / 8.3" rear
Approach angle = 43.1-44.9*
Departure angle = 27.7-28.4*
Breakover angle = 21.4-22.1*
jlb27537 is offline
post #3 of 5 Old 08-18-2015, 10:26 AM Thread Starter
forthetimebeing
Thank you for all that info!
And please forgive my ignorance, but which set of specs is the Unlimited 2-Door? I thought the TJ was the Unlimited 2-door, but you have its wheelbase being LESS than the LJ, whatever that is (sorry, not up on the lingo).
What I really need to know is the wheel base length and width of the 2006 Unlimited 2-door compared to the other (smaller) 2006 2-door models. Current specs for current 2-doors would be nice for comparison as well.
Many thanks.
Steven
post #4 of 5 Old 08-18-2015, 10:51 AM
jlb27537
The LJ is 10" longer than a TJ The LJ is the 2004-2006 Unlimited. (long 2 door) "LJ = long jeep???? is how I remember.
https://www.jeepforum.com/forum/f9/st...ations-452871/
https://www.jeepforum.com/forum/f96/j...reads-1074059/
jlb27537 is offline
post #5 of 5 Old 08-18-2015, 11:36 AM Thread Starter
forthetimebeing
Okay, gotcha. I am surprised the wheelbase is not wider as well as longer. I thought that was the main thing for the added towing capacity. Sure seems wider than other 2-doors.
Anyway, many thanks for the help with this.
2006 , unlimited , wheel base , wrangler
