first jeep purchase 89 yj bad choice? Help :) - JeepForum.com
post #1 of 2 Old 06-24-2016, 09:04 AM Thread Starter
haysanatar
I'm about to buy my first jeep, a 1989 yj with 230k miles, and I just want to make sure I'm not about to make a horrible decision. Any input or advice is definitely appreciated!
The original asking price was $3800 I have him down to $2700 cash.
The body is straight the only rust spots on the jeep are the fenders which do need to be replaced. The paint is pretty faded (who cares) and could use a new paint job (after the fenders are put on anyways..)
The body is perfectly straight it still has the original bumper and winch. The frame is straight and is rust free for the most part. The only place there is any rust is between the rear tire and back connection for the leaf spring. it has a small area of frame rot on both sides in that same location a quarter -half dollar size rusted hole but its solid around that area with no surface rust. Seats are worn(who cares) the tub is rust free and in great shape.
The engine is the 4.2l i6 with the original air cleaner and carb. The air intake accordion hose has pretty much degraded to the point 25% of it at the base is just open air flow. There does seem to be a vacuum leak and a small exhaust leak that should be an easy fix. Thankfully it has the ax-15 tranny and not the puegot. The engine idles decently well but not perfect (vaccum leak and air intake being just open almost???) when its up in rpms the engine sounds very solid and strong (no ticking lifter noise like the 4.0's I've heard) Transmission shifts into all gears fine and the 4x4 seems to engage as well with no issue. The engine ofcourse does appear to be leaking a little oil but I couldn't tell where from. One little oddity the guy seemed to have been running 100% antifreeze in the car... and I cant figure out why. Would a thicker antifreeze leak less if there was a blown gasket or could it be an over heating problem?
Any input would be great!
haysanatar is offline
post #2 of 2 Old 06-24-2016, 09:53 AM Thread Starter
haysanatar
The two rust spots on the frame
advice , first jeep , jeep , YJ
