First Jeep - JeepForum.com
post #1 of 3 Old 01-31-2019, 09:21 AM Thread Starter
abby5846
First Jeep
So, I’m looking to buy a 2000 Wrangler Sport. It doesn’t have the hard top or full doors but I’ve found both the top and doors off a 97 TJ. Will everything fit correctly? The top is also cracked on the back corner. Will that be a problem or is it easily fixable?
abby5846 is offline
post #2 of 3 Old 01-31-2019, 10:41 AM
HAZCAT
HAZCAT's Avatar
The top and doors will fit but always remember that the body of the 2000 may have been tweaked a bit over the years from wheeling or a wreck or whatever and can still cause issues. I put on 97 TJ full doors and a 2000 TJ hardtop on my 98 TJ. I also kept my 98 half doors and added door uppers with hard windows instead of the zipper windows and used them with the hardtop. The crack would be the real issue as those tops are plastic and not fiberglass. You can use some caulk to squeeze in the crack from both sides once you get it on the Jeep and it's bolted down. But that crack may get larger as you take the top off all the time.
'84 CJ7, 44, 14 bolt, twin stick 300, 109"whl base, 4 linked
'93 XJ Cherokee
'70 CJ6 Dauntless v6
HAZCAT is offline
post #3 of 3 Old 02-06-2019, 03:54 PM
bharris68
Unsupervised Adult
If you've got the jeep - you can try drilling out the crack on each end - small hole - like an 1/8" - buy a new bit or sharpen it so you drill straight and true. I've found that for plastic, SUGRU works REALLY well to make cracks 'vanish' and watertight as well. Just make sure you find the right color - clean the area with something like a cloth with a little bit of chlorine-free brake cleaner or xylene so that the SUGRU will hold/adhere.
bharris68 is offline
I own a xj jeep.....what happened? CORRIE-XJ New Members/Introductions 2 11-24-2018 08:19 AM
2012 Jeep Liberty Transmission Failure P3ppy911 KJ Liberty Forum 1 08-15-2018 01:45 PM
Announcing Jeep Beach Jam 2018, May 15th-20th JeepBeachJam Vendor Display 0 02-15-2018 08:48 AM
258 Jeep YJ Rough/Rich idle - Post nutter zgeorge YJ Wrangler Technical Forum 4 12-21-2017 05:47 PM
