Factory Settings Throw Off - JeepForum.com
post #1 of 2 Old 11-23-2007, 11:29 AM Thread Starter
rock licker
I just bought my first jeep! '99 Sahara, manual shift mostly all stock from what I can see. I live in some pretty rough country (badlands of SD) and want to put some 31's possibly and a 1 or 2 inch lift. The guy at the tire store said to "not mess with the stock set up because it will throw off the computer, the factory ride, the gears, the speedometer, lose power". Now I'm all confussed because I see almost every jeep lifted with big tires! Are all those jeeps messed up or was the tire guy just "one of those guys"?
I don't want to lose all that or have to get into changing everything just for the few changes I want.... will I have to do all that?
Any help would be great.
Thanks......
rock licker is offline
post #2 of 2 Old 11-23-2007, 12:45 PM
XJK
The Guru of Nothing
XJK's Avatar
as for computers i wouldnt worry too much about that.
but putting bigger tires will throw off the spedo, if thats a big deal to you then you can easily fit it by throwing in a new spedo gear. the gear ratio will be a little off causing a slight loss of MPG and you will have a slight loss of power all as a result to the larger tires. now is this a big deal? i run 31's and none of the above mentioned are a problem to me so i would go ahead with it especially if its going to help with the terrain that you are frequent to.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
factory lift kits? sjc115 Jeep Buying Forum 2 07-10-2009 05:55 AM
Factory To Dealer Incentives spolebitski Jeep Buying Forum 6 11-07-2008 06:19 PM
Factory Cruise Control? weirdaljr Jeep Buying Forum 4 10-05-2008 08:44 PM
Latest Factory Incentives ? Katmandu Jeep Buying Forum 1 01-03-2008 01:34 PM
