buying YJ advice - JeepForum.com
post #1 of 7 Old 02-08-2010, 05:07 PM Thread Starter
nyyj
Guest
buying YJ advice
hi
im new to the forum and always wanted to get a wrangler and time has come when my DD died and it's time to replace it. i understand that YJ may no be the best choice for DD but im willing to give it a shot.
i found 95 YJ 4.0 I6 with AUTO (although wishing it was MANUAL) transmission with somehow high miles of around 140k. i haven't seen the car yet but it has hard top/full doors(doors don't match the color of the car - i guess i can repaint later). seller said there's some rust on passenger front fender which will cost $100 to replace (again will need to match color). there is small hole in pass floor pan but nothing that a sheet of metal can't cover up. he said the interior is in very good condition and little rust on the frame but nothing major. seller says 4x4 n tranny are good, drive and shifts smooth, again I need to check that. price is around $2500-$3000. is it priced right or should i look elsewhere?
jeep is located 2hr away from me so i will most likely pick it up when im there to test/inspect it. what are the things that i need to look for when it's time to test/check it? thanks in advance for your input.
nyyj is offline
post #2 of 7 Old 02-08-2010, 05:25 PM
Stefan
Look elsewhere, and if I were you, I'd go for a TJ. They're rated best used wrangler buy...easiest to maintain and work on...and by far most reliable.
Check out the write up in JP magazine about used TJ's
-Stefan Snorrason (1997 TJ a.k.a Eloisa or Jeppi)
Stefan is offline
post #3 of 7 Old 02-08-2010, 06:47 PM Thread Starter
nyyj
Guest
thanks for your advice. i sort of like the YJs square lights more than the TJs circles, although the interior is a bit better in TJ yet more crampy. are you saying that the price is too high for the specs/condition listed above? i'd think that TJs cost more than that and i'm not on very high budget.
nyyj is offline
post #4 of 7 Old 02-08-2010, 07:11 PM
Kerner
1980 CJ7
4.0, Auto, hard top and doors. It is a valuable Jeep if taken care of. A little rust is okay if it only needs a fender or hole patched. If it's worse than he describes, which they usually are, if you can do the work yourself and get a good price. Look for leaks, rusted frame. Loose steering/suspension parts, ball joints, tie rods, u-joints. Shifts okay, doesn't overheat. Give it a good test drive, make sure it gets up to temp and you run it a little hard. Recent brake job? Tires? maintenance?
From what's been explained here, NY is a higher priced area, if you could get this around $2200-2500 you'd probably be alright and have a little in your pocket towards some of the work.
High mileage 97 TJ similar options would still be $6K-$8K range.
Kerner is offline
post #5 of 7 Old 02-08-2010, 07:35 PM
Stefan
Well you can craigslist a good TJ and find someone just lookin to get some cash...I've seen real steals on there.. for pretty good TJ's...you may wanna check craigslist.
Stefan is offline
post #6 of 7 Old 02-09-2010, 12:37 PM
lower11
Thats a pretty good price. Not great but good. If you could save a little more $$$$ and hold off on a vehicle im sure you can find a better one. But even after you buy one you will find a better deal out there. It seems to always happen.
I paid 4300 for mine. 1995 YJ, 108k, no rust. interior was rhino lined, 33's and 3 inch lift. Found it on craigslist.
lower11 is offline
post #7 of 7 Old 02-09-2010, 01:11 PM
Stefan
Craigslist is like jeep meccah...have you ever just typed in "Jeep" to the search space?
Stefan is offline
Need buying advice*** watisgood Jeep Buying Forum 2 03-23-2009 07:48 PM
Looking for some advice on buying a zj Kota04SXT Jeep Buying Forum 2 06-03-2008 07:22 PM
Need advice on buying ZJ V8 or not??? havasu1 Jeep Buying Forum 1 05-25-2008 05:26 PM
Need advice on buying a TJ MIAJeep Jeep Buying Forum 9 05-19-2008 01:22 PM
Looking at buying a new KJ - need advice. K11 Jeep Buying Forum 2 02-08-2008 03:22 PM
