78 Waggie: What is causing this misfire? - JeepForum.com
post #1 of 1 Old 03-05-2019, 08:38 AM Thread Starter
Cantaloupeman
Cantaloupeman's Avatar
So I'm looking at buying a 600 dollar Wagoneer with quite a bit of body damage, and a misfiring engine. It misses on one or two cylinders according to the ad, but it starts right up. The engine dies however when you start to drive it. The owner says his next repair was replacing the cylinder heads, but I'm not sure if that's what's actually the problem. What else could be the cause? I don't want to buy this thing if I'm not gonna be able to get it driving.
Recent repairs:
Rebuilt carb
Fuel pump
Fuel filter
Coil
Starter
Distributor
ECU
Alternator
Cantaloupeman is offline
'03 4.0 misfire (only at higher rpm) Cam137 WJ Grand Cherokee Forum 8 09-09-2018 01:00 PM
Cylinder 4 misfire Dakota4G63 ZJ Grand Cherokee Forum 2 09-04-2018 04:35 PM
4.0 misfire codes and weird compression test results Dborns Jeep CJ Forum 65 06-28-2018 03:03 PM
Intermittent misfire Dborns XJ Cherokee Technical Forum 23 06-22-2018 02:43 PM
Misfire cyl 2 99 4.0 liter WJ autotech1 WJ Grand Cherokee Forum 11 02-17-2018 04:42 PM
