Expedition Trailer w/ Roof Top Tent $7500 - JeepForum.com
post #1 of 1 Old 06-28-2019, 10:18 AM Thread Starter
bfr
bfr's Avatar
$7500 W/ Tent, $6500 W/O Tent
Located in Cleveland, GA 30528
Built in 2012
Approximately 12,000 miles, since built.
Powder Coated
Stored indoors when not in use
Multi Axis hitch
7 pin wiring (can work w/ 4 flat adapter, but only the STT and marker lights when doing so)
3500lb axle w/ electric brakes
255/85R16(33) BFG KM2 tires
Jeep Wrangler (TJ) Rubicon Wheels (Requires the use of spacers to clear the hubs)
Springs are from the rear of a pre taco Toyota truck
Mombassa Adventure Annex RTT
Marinco/ Guest onboard charger (can charge batteries from shore power or tow vehicle)
Blue Sea Systems switch/ fuse panel
Two 12v deep cycle batteries
All LED Lighting (STT, Marker Lights, LED Cube Reverse Light)
ARB 50 QT fridge
Water heater
2- 11lb propane tanks
25 Gallon fresh water tank w/ 12V pump
interchangeable double & triple Jerry Can Mounts
The entire center section floor is mounted to a slide that can be stood on when fully extended
10 Cantilever Umbrella
Rear receiver hitch/ recovery point
Known Issues
I had to re-sew a few inches of the zipper to the tent fabric just above the ladder.
The lid of the trailer (under the tent) is marked up from my storing my upper doors there for thousands of miles
I put the trailer on its side in New Mexico a couple of years ago, which scratched the lid & fender, and broke a marker light (I replaced the light, I have always viewed the scratches as trophies)
bfr is offline
