5 speed 1995 Jeep zj grand Cherokee - JeepForum.com
post #1 of 1 Old 05-22-2019, 03:19 PM Thread Starter
Tolan95
Tolan95's Avatar
I have a 1995 Jeep Grand Cherokee with 141,xxx miles. Built it for a weekend trail rig and daily driver. Itís not quite daily driver status, but will drive around town and 65-70 mph no problems. Itís 5 speed swapped, has a Dana 30 High pinion front axle that was just regeared to 3.73 to match the Ford 8.8 rear axle with a freshly rebuilt LSD. Iron rock off road front and rear track bars, rough country X-flex 4.5Ē lift. Currently sitting on 16Ē Mickey Thompson classic lock 2ís wrapped in 33Ē general grabber AT2s. Needs front upper adjustable control arms and an alignment to finish it out correctly. $2500 you can drive it away or $1500 bring your own rims/tires.
LOCATED IN CENTRAL IOWA 50 MIN NORTH OF DES MOINES
2005 TJR 4.0L 6 speed manual
Tolan95 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3856 07-28-2019 09:18 AM
1995 Jeep Grand Cherokee FSM?!? BigRedCornhead ZJ Grand Cherokee Forum 3 03-30-2019 07:33 PM
Fitting a box spring inside a 1995 Jeep Cherokee? ChloeAntionette XJ/MJ Cherokee Non-Technical Forum 1 04-11-2018 06:19 PM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
1997 jeep speed assembly MedixRun TJ Wrangler Technical Forum 3 12-24-2017 11:28 AM
You may not post new threads
