2012 Jeep Wrangler JKU - JeepForum.com
post #1 of 2 Old 05-08-2021, 01:28 PM Thread Starter
RalphTomaccio
VERY CLEAN - MUST SEE TO APPRECIATE
2012 Sport S Package, Deep Cherry Red, 6 Speed Manual Transmission
Low Mileage: Less than 50,000 miles
A/C, Power Windows, AM/FM Radio w/8 Speakers
Limited Slip Differential w/3.73 Gearing
Tow Package w/Hitch & CURT Manufacturing 45036 Class III 2" Loaded Ball Mount
Nitto Ridge Grappler Tires, 285/70R/17C (installed at 29,538 miles) - Very Quiet on road!
Rock Krawler 2.5" Flex System Suspension Lift (4” net lift)
Rock Krawler Adjustable Front Lower Control Arms
Rock Krawler Sway Bar Quick Disconnects
Front Brake Line Extensions (Replaced 10/30/19)
Parking Brakes (Rebuilt 10/30/19)
Bilstein 5100 Shocks
Tom Wood’s Front Drive Shaft
EBC Front & Rear Brake Pads (Installed at 28,282 miles on 7/6/2016)
Alloy USA Front Upper & Lower HD Ball Joints (Installed on 11/04/2019)
TnT Skids: Engine Oil Pan, Transfer Case, Gas Tank
Lower Control Arm Skids
Rock Hard Evaporation Relocation Kit
Poison Spyder HD Crossmember
Rubi Rails
JKS Steering Stabilizer Relocation Bracket
Teraflex HD Steering Stabilizer
Teraflex Exhaust Spacers
Viair 450P OBA w/Front Bumper Air Line Connector, Dash Mounted On/Off Switch
JKS LCA Hardware Upgrade
Warrior Hood Hydraulic Lifts
Cobra 75 CB w/4’ Firestick Antenna & Quick Disconnect
Uniden BC23A Amplified External CB Speaker
Superwinch Bumper & TS9500 Winch w/Cover
Spring Clip Roller Fairlead License Plate Holder
Hardtop Quick Disconnect T-Bolts & Panel Removal Tool
WeatherTech Front, Rear & Cargo Mats
Door Entry Guards
Front & Rear Side Grab Handles
Maglite ASXD026 D-Cell Flashlight Mounting Brackets on Drivers Seat Frame
Thule Roof Tracks with Cross Bars
$25,000 (Please refer to the Kelly Blue Book Valuation below)
Negotiable Items:
Harkin 4 Point Hard Top Garage Lift
RoadPro SWR/Power Meter for Tuning CB Antenna with Redman CB Made 3’ RG8X COAX Gray Jumper
ARB ARB705US 2-3/8" x 30' Recovery Strap - 17500 lbs. Capacity
ARB ARB730 10’ Tree Trunk Protector
ARB 10100380 Strap Wrap
ARB ARB503 Orange Compact Recovery Bag
1/2” Drive 24” Flex Head Extra Long Ratchet/Breaker Bar w/21mm Deep Socket for Wheel Lugs
Solid Rubber Wheel Chocks
Powerbuilt Unijack - 4,000 lb. Capacity (Jack Stand w/ Built-in Bottlejack)
RalphTomaccio is offline
post #2 of 2 Old 06-04-2021, 01:33 PM Thread Starter
RalphTomaccio
SOLD for $24,000!
You may not post new threads
