2009 Jeep Wrangler - JeepForum.com
post #1 of 5 Old 08-10-2020, 08:58 PM Thread Starter
BHedlund1989
2009 Jeep Wrangler
I'm listing my buddies 09 Jeep Wrangler Unlimited for him. There's honestly too much list on it so bear with me. It has around 49,000 miles on it and everything has been either replaced or upgraded on it sometime or another. From my estimate there's an easy 25 grand in aftermarket parts on it.
25,000 obo
The Basics:
4"Synergy Long Arm Lift Kit
Tom Woods Driveshafts
4.88 Gears with Arb Air lockers with chromo axles done at the same time
Entire tub was professionally Line-X
Superchips Flashpaq
Dual exhaust
Airhorn with air compressor in the rear
37" Goodyears
Hi Lift
Much much more
2000 WJ Laredo
IRO 3" on 265/75/16 JK takeoffs
BHedlund1989 is offline
post #2 of 5 Old 08-17-2020, 10:22 PM Thread Starter
BHedlund1989
Synergy Manufacturing Steering Stabilizer Tie Rod Clamp
https://www.quadratec.com/products/16315_600X_C_PG.htm
FOX STEERING STABILIZER IFP JK
https://www.quadratec.com/products/16335_2002.htm
Synergy Manufacturing Steering Stabilizer Mount
https://www.quadratec.com/products/16315_600X_PG.htm
Synergy Manufacturing Front Track Bar Bracket
https://www.quadratec.com/products/16315_60XX_A_PG.htm
Synergy Manufacturing Front Adjustable Track Bar
https://www.quadratec.com/products/16315_6XXX_PG.htm
Synergy Manufacturing 8002 Chromoly Tie Rod
https://www.quadratec.com/products/16315_6000_07.htm
Synergy Manufacturing PPM-8000-01 High Steer Drag Link Kit
https://www.quadratec.com/products/16315_6001_07.htm
Covercraft C16960-TT Block-it 380 Car Cover in Tan
https://www.quadratec.com/products/11088_0211_07.htm
Bestop 54723-35 Supertop NX Soft Top with Tinted Windows
https://www.quadratec.com/p/bestop/5...r-jk-unlimited
Alloy USA 12156 Rear Grande 30 Spline Peformance Axle Kit
https://www.quadratec.com/products/52400_607_07.htm
Alloy USA 12155 Front 30 Spline Chromoly Axleshafts
https://www.quadratec.com/products/52400_511_07.htm
Crown Performance Products 104" Heavy Duty Airline Kit
https://www.quadratec.com/products/12706_51X_PG.htm
Crown Performance Products 48" Heavy Duty Airline Kit
https://www.quadratec.com/products/12706_50X_PG.htm
Mopar 82210166AD Floor Slush Mats with Tire Tread Pattern
https://www.quadratec.com/products/14152_0015.htm
KC HiLiTES KC Rally 800 Series Pair Long Range 130W Super White Light
KC HiLiTES SlimLite 100W Super White Driving Pair Pack
https://www.quadratec.com/products/97048_X1_PG.htm
Delta Tech 01-1198-50X 7" Round Quad Bar Xenon Headlight Kit
https://www.quadratec.com/products/97009_301.htm
ARB Competition Differential Cover for Dana 30 Axle Assemblies
https://www.quadratec.com/products/12011_900X_A_PG.htm
ARB Competition Differential Cover for Dana 44 Axle Assemblies
https://www.quadratec.com/products/12011_900X_PG.htm
Rugged Ridge Rear Side Grab Handles
https://www.quadratec.com/p/rugged-r...rab-handles-jk
Crown Performance Products 5 Layer Custom Extended Brake Lines
https://www.quadratec.com/products/12706_63X_PG.htm
ARB High Performance On-Board Compressor for ARB Air Lockers
https://www.4wd.com/p/arb-high-perfo.../R-BHWQ-CKMA12
Crown Automotive D30JK488 4.88 Ratio Dana 30 Ring and Pinion
https://www.quadratec.com/p/crown-au...-30-front-axle
Crown Automotive D44JK488R 4.88 Ring & Pinion Set
https://www.quadratec.com/products/52419_0087.htm
ARB Dana 44 30 Spline 3.92 Ratio Up Air Locking Differential - RD116
https://www.4wd.com/p/arb-dana-44-30..._/R-BHWQ-RD116
ARB Dana 30 30 Spline 3.73 Ratio Up Air Locking Differential - RD104
https://www.4wd.com/p/arb-dana-30-30..._/R-BHWQ-RD104
Synergy Manufacturing Stage 4 Long Arm Lift Kit
https://www.quadratec.com/products/1...ZGHu-u-n0qFtXA
2009 Jeep Wrangler (JK) Smittybilt XRC Gen 1 Front Bumper (Black) – 76806
https://www.4wd.com/p/smittybilt-xrc..._/R-DSBP-76806
2009 Jeep Wrangler (JK) Smittybilt XRC Gen 1 Rear Bumper with Hitch and Tire Carrier (Black) – 76856
https://www.4wd.com/p/smittybilt-xrc..._/R-DSBP-76856
Smittybilt 76895 XRC Rock Sliders in Textured Black
https://www.quadratec.com/products/12057_2201_07.htm
Optima Yellow Top Deep Cycle Battery, Group Size 35, 620 CCA
https://shop.advanceautoparts.com/p/...000%7CL3*15597
Goodyear 750578326 Wrangler MT/R Tire with Kevlar in 37x12.50R17
https://www.quadratec.com/p/goodyear...0r17-750578326
Pro Comp Series 05 Wheel in Black
https://www.quadratec.com/p/pro-comp/series-05-wheel
6-Switch Control Panel Box for Jeep Wrangler JK JKU LED Lights Bar Rock Lights with Wiring Kit& Source System Relay Electronic Control System
https://www.amazon.com/6-Switch-Cont...ct_top?ie=UTF8
Rhino lined interior floor front to back (no carpet)
LineX front Stock Grill.
Crown Automotive 55056642AD Fan Module Assembly
https://www.quadratec.com/products/51203_0006.htm
Smittybilt X2O 10 GEN2 10000lb Recovery Winch PAK
https://www.4wheelparts.com/p/smitty...BP-GEN2WINPAK6
Fox® Racing Shox Front 2.0 Performance Series Remote Reservoir Shock
https://www.quadratec.com/products/16335_410X_PG.htm
Fox® Racing Shox Rear 2.0 Performance Series Remote Reservoir Shock
https://www.quadratec.com/products/16335_410X_A_PG.htm
Rugged Ridge Modular XHD Snorkel Kit
https://www.quadratec.com/products/17011_0011_07.htm
MasterTop Cable Style Bimini Top Plus in MasterTwill® Fabric
https://www.quadratec.com/p/masterto...limited-4-door
Smittybilt 581035 CRES - Cargo Restraint System in Black
https://www.quadratec.com/products/14070_9304_07.htm
2000 WJ Laredo
post #3 of 5 Old 08-17-2020, 10:26 PM Thread Starter
BHedlund1989
There's also a viper autostart
Smittybilt fenders front and rear:
https://www.quadratec.com/products/1...m_campaign=cse
https://www.quadratec.com/products/12528_1414_07.htm
2000 WJ Laredo
post #4 of 5 Old 08-27-2020, 10:20 PM Thread Starter
BHedlund1989
23,000 obo
2000 WJ Laredo
post #5 of 5 Old 09-14-2020, 09:32 PM
bcessario
bcessario's Avatar
1987 YJ Wrangler
I can’t see the pics
bcessario is offline
You may not post new threads
