2004 Grand Cherokee WJ Limited, Long Arm 35s Bypass Shocks - JeepForum.com
post #1 of 2 Old 02-02-2020, 04:52 PM Thread Starter
LSRGreg
2004 Jeep Grand Cherokee Limited w factory Nav, all options. Crystal black metallic. 128k miles. asking $9000 obo located in Phoenix AZ.
Factory tow package w/ brake controller.
It’s a real head turner and super capable offroad. It’s super clean and in great condition. It does have some AZ pinstripes from wheeling. Most people can’t believe what it can do, and does it easily with lots of comfort and can still drive down highway at 80mph. This Jeep has been my passion and obsession for many years and it’s in great shape with lots of life left.
4.7 HO engine
Trasfercase swapped for 242. 2WD and 4WD part and full time with low range.
Front axle: Dana 30, trussed, sleeves, 4.56 gears, high steer and HD tierod steering link. Rotated housing for better driveline and caster angle. Factory vari-lock diffs, steering stabilizer. Extended u joint driveshaft, c knuckle gussets, synergy grease-able hd ball joints
Rear axle: Dana 44HD. 4:56 gears, factory vari-lock diff (comes with truss not installed) Tom Woods rear driveshaft.
Suspension:
Clayton Long Arm kit. 6” rear springs, 8” front for leveling and winch bumper. Front upper joints converted to grease-able Johnny joints, 4 link rear, relocated traction bar front with grease-able Johnny and summit machine joints. 1 ton steering end joints. Coil spring retainers. Custom Currie Anti-Rock sway bar. 12” travel 2” Fox 3 tube bypass shocks with 3D CAD designed and laser cut custom shock mounts and custom tuned valving by Fox for this Jeep. Lots of adjustment for smooth street ride/ rock crawling or high speed off-road.
Wheels/Tires
General Grabber 35x12.5x17
Walker Evans Racing wheels. With true beadlocks. Monster valves for super fast air down and fill up.
Armor:
Incline winch bumper with 8k winch. Protects factory radiator mount. Riddler front diff cover, KOR Rock Sliders, steel belly skidplate that mounts to Clayton subframe. Control arm mount skids
Other:
Power steering pump set up for hydro assist ram. Flowmaster 40 w/ turn down.
AC blend door fix
Fenders trimmed, bent for clearance at full compression. Washer bottle relocation. Everything powder coated but color is faded. HID bulbs in normal and high beams, also in bumper lights, and LED reverse bulbs. Winch Control from center console, Antilock brake defeat switch,
Needs:
Hyd cooling fan has small leak, and comes with complete replacement system ready for install.
6C28B3B7-55FB-40AB-B23F-B6DBCDE882AB_1580683741103.jpeg   198DF8C8-62B0-46BE-9A14-4037F4F430F9_1580683753362.jpeg
04 WJ, Limited, 4.7 HO, w/ lots of goodies
Incline Winch bumper from WWW.FRANTZDESIGNWORKS.COM
LSRGreg is offline
post #2 of 2 Old 02-12-2020, 07:24 AM Thread Starter
LSRGreg
SOLD!
LSRGreg is offline
You may not post new threads
